Old 10-25-2019, 06:27 PM   #1
chevellelover
chevellelover
chevellelover's Avatar
1973 C20 2wd build thread
This is my build thread for my 1973 C20
2wd 454/th400 4:10 14 bolt posi
1978 Trans Am 400/4speed Year One Snowflakes
1980 c10 shortbed
1999 Suburban 5/7 drop US Mags Roadsters
1999 GMC Sierra Classic 4x4-MINT
2015 Challenger Scat Pack 6.4 8 Speed
chevellelover is offline   Reply With Quote
Old 10-25-2019, 06:31 PM   #2
chevellelover
chevellelover
Re: 1973 C20 2wd build thread
Added some LED Tail lights and LED Side Marker Lights
Will update as I add parts as this is my #1 project for the next few months
1980 c10 shortbed
Old 10-25-2019, 06:33 PM   #3
chevellelover
chevellelover
LED they are yellow not amber. I will try to get used to them
1980 c10 shortbed
Old 10-28-2019, 12:22 PM   #4
chevellelover
chevellelover
Added Aluminum radiator and electric fans. Ebay kit not bad for $200
1980 c10 shortbed
Old 10-29-2019, 07:29 AM   #5
naphtali5725
naphtali5725's Avatar
what radiator kit did you buy?
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 10-29-2019, 11:07 AM   #6
chevellelover
chevellelover
C10 Radiator and Fan combo from ebay. came with relay and temperature sensor as well. $200+tax
1980 c10 shortbed
Old 10-29-2019, 11:08 AM   #7
chevellelover
chevellelover
G force trans crossmember with new trans mount installed to tuck new exhaust coming soon above the frame rails.
1980 c10 shortbed
Old 10-29-2019, 11:11 AM   #8
chevellelover
chevellelover
New Grant steering wheel. (stock is worn and sticky) $160
New 33 inch tilt column 2 inches shorter then stock i believe so gear shifts are tight and precise and more room inside the cabin. $280
1980 c10 shortbed
Old 10-29-2019, 11:18 AM   #9
chevellelover
chevellelover
Big Block Chevelle Longtubes are next (do not hang below the frame rails) new 3 inch exhaust with x pipe and Magnaflows. Have 3 inch Flowmaster 50's on the truck now but need more clearance and the Flowmasters are robbing power.
1980 c10 shortbed
Old 10-30-2019, 06:59 AM   #10
naphtali5725
what seller was it on ebay?
My build thread...
Disabled Veteran
