11-19-2019, 03:28 PM | #1 |
Brake booster that fits a 1970 C/20?
Hi all, new here and to the Chevy truck world. Amazed by how cheap and accessible the parts are, but I cannot source a brake booster which seems crazy given how many of these trucks are still in service. Summit told me Cardone 50-1101 is the right part, it looks like what's on there now, but even Cardone doesn't have them.
What are you using on your 3/4 ton? Thanks! |
11-20-2019, 08:29 AM | #2 |
Re: Brake booster that fits a 1970 C/20?
I could not get one for a ‘72 reman either. I wound up buying a Speedway Motors booster/bracket/master/combination valve kit.
The drum brake booster is different than the late disc booster. If you are adding power brakes and not just repairing a booster, know that these trucks have a bracket that offset mounts the booster and use a linkage to actuate. You need all the parts to convert not just aa booster like on later vehicles.
11-20-2019, 11:09 AM | #3 |
This is what I am using with my 70 C20. Works great and is exactly like the original that I pulled out. It is a dual 8.75" diaphram.
https://www.napaonline.com/en/p/NBB5...ndex=Universal |
11-20-2019, 11:14 AM | #4 |
Check out the setup Frank sells. I have the 1/2 ton version and it works great!
http://67-72chevytrucks.com/vboard/s...d.php?t=581862
72 C10 lwb fleetside -stock 350/350 combo |
11-20-2019, 09:47 PM | #5 |
Couple years ago I bought a replacement booster an master cylinder from Oreilly auto parts matched the original
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
