Old 11-09-2019, 11:03 AM   #1
Andy4639
Old member
Andy4639's Avatar
Talking First run!
We have been working on my daughter's 68 step side. We had a few minor problems with getting the motor to fire but yesterday we over came them and she fired up for the first time. We tried 2 old start's my buddy had at his shop. Neither one would work. I bought a mini starter from O Reilly's and it was bad. Got the second one from them and still no start. We did some adjusting and figured out it was battery related.
Had a older battery and tried using it with no luck. Got another one out of a vehicle that ran but it died on us while trying to crank it. I pulled the battery out of the Ramp truck and it fired right up!
Here is the first start of it.
Hope to have the cab set by Thanksgiving maybe.
Here are few pictures of the chassis & cab on the lift and the old LWB frame.
https://www.youtube.com/watch?v=tFq_F39i1cE
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-09-2019, 09:20 PM   #2
YoungPup1977
Re: First run!
In the video, is that a fresh rebuilt engine ? asking for a professional engine builder.
YoungPup1977 is offline   Reply With Quote
Old 11-09-2019, 09:45 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: First run!
Yes as in very first start up. My friend who helped me build this and my 71 C 10 37 years ago is a professional builder also and he has more knowledge than any one person I know except one. When it comes to Chevy engines are anything on a vehicle.
This was a test run to check it before setting the sheet metal.
He also went through GM training facility training under the only man I know that knew more than him. The best mechanic GM had in the 70's, he was head instructor in Charlotte NC for 9 years, my dad who retired with 35 years with GM and is 94 now.
Old 11-09-2019, 09:57 PM   #4
Getter-Done
Getter-Done's Avatar
Re: First run!
Great job.
I seen the video.
I am glad you are adding the typed U tube link
I had to look back to your older post to find the golf cart stuff
on some of your earlier post / Cause my computer did not
accept the earlier U tube post you shared.
I'm all caught up on your u tube post now.
Thanks for sharing.
You are making fast progress of this.
Nice.
84 Chevy K-20
Old 11-09-2019, 10:21 PM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: First run!
Originally Posted by Getter-Done View Post
Great job.
I seen the video.
Thanks for sharing.
Nice.
Thanks, I think it's gonna get slower now. I got a lot of welding to do and grinding. I have rockers and corners and such to repair. Did I mention I got a lot of grinding to do!
Old 11-10-2019, 12:36 AM   #6
Captainfab
60-66 Nut
Re: First run!
Your engine must have a roller cam in it since your expert mechanic did not perform the cam break in immediately.
Old 11-10-2019, 10:50 AM   #7
YoungPup1977
Re: First run!
I dyno all my engines in house to ensure its ready to be installed.
Old 11-14-2019, 03:28 PM   #8
biketopia
Re: First run!
Also no water pump...
But, it does sound good, open manifold or was through the exhaust? Stock re-build or??
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 11-14-2019, 04:46 PM   #9
YoungPup1977
Re: First run!
Glad it fired up for ya. Should turn out
Real nice in your truck. Good luck to your build !!
Old 11-15-2019, 12:02 AM   #10
Andy4639
Old member
Andy4639's Avatar
No water just ran it long enough to know it would run.
60lbs of oil also.
Stock build no exhaust hooked up yet.
Old 11-15-2019, 12:04 AM   #11
geezer#99
geezer#99's Avatar
Re: First run!
Hydraulic flat tappet or roller cam?
Old 11-15-2019, 12:17 AM   #12
Andy4639
Old member
Andy4639's Avatar
Neither just a stock 350.
Old 11-15-2019, 01:07 AM   #13
geezer#99
geezer#99's Avatar
Re: First run!
Which makes it a hydraulic flat tappet cam.
Running it like that also makes it potentially a flat cam lobe cam.
You can’t idle them like that on first start.
Makes for rounded cam lobes.
You might get lucky and have no damage or you’ll get to start over.
Time will tell!
I’m sure a dozen will come along and say I’m full of crap. Won’t hurt it.
Another dozen might agree with me!
But at least one thing might be good. Your super experienced engine guy will be happy to pick up the tab for the rebuild!
Old 11-15-2019, 11:03 PM   #14
Andy4639
Old member
Andy4639's Avatar
Time will tell!
I don't know if your right are wrong. But I know this man and he built my 307 TPI motor and we did it the same way and when I pulled it out almost 30 years later it was still running with over 250,000 miles on it so for what it's worth I go with him and his expertise. By the way he would pick up the tab if he thinks it's his fault. That's the kind of guy he is.
Old 11-16-2019, 10:17 AM   #15
YoungPup1977
Re: First run!
If it works for you, go for it. All this is, a forum to share ideas and opinions. Thats all. If you want to debate from right and wrong maybe the forum needs its name changed.
We can debate professional engine builder vs a super dupper experienced mechanic.....debate engine break in. Do i support the way the engine was fired up. Who really cares if i do or not. It works for him.
Old 11-16-2019, 10:48 AM   #16
geezer#99
geezer#99's Avatar
Re: First run!
You should start your own forum DF!
Old 11-16-2019, 11:31 AM   #17
YoungPup1977
Re: First run!
Really ? Its only an opinion.... what is DF ? Is this same as your private message you sent me that called me a dumb f. U. C. K. DF ?????
NICE !!!! Thanks. Must be against your forum rules !!!!
I think geezer must want me Suspended from this wonderful forum !!! Maybe it will work against him but whatever happens Happens !!!!!!!!
Old 11-16-2019, 12:38 PM   #18
MySons68C20
MySons68C20's Avatar
Re: First run!
To each their own regarding break in. We are firing up a fresh 331 Ford today with a flat tappet hydraulic cam and will run it for 30 minutes @ 2200 -2500 rpm.
We pre lube and use Brad Penn high zinc break in oil.
I'm sure others get away with doing less or different but this is my opinion of the best way.......There's more than one way to skin a cat though
MySons68C20 is offline   Reply With Quote
Old 11-17-2019, 06:59 AM   #19
Andy4639
Old member
Andy4639's Avatar
This video was done before we fired up the engine.
Notice we had 60lbs of oil pressure to the motor and I ran that drill like this until the drill motor went dead. So it pumped the oil all through the engine. The engine wasn't dry started.
I would have thought since I'm in the Engine area I didn't have to state this, but I guess I was wrong.
This is the 2nd engine I have helped him build and if it last's half as long as the first I'll be very happy! The first one had over 250,000 miles on it when I pulled it out for the LS swap.
https://www.youtube.com/watch?v=2nAYx06TUMQ
Old 11-18-2019, 12:58 PM   #20
vince1
Re: First run!
Maybe it is just me but I find the red type hard to look at. I skip over it and it's nice to read the other posts.
vince1 is offline   Reply With Quote
Old 11-19-2019, 06:20 AM   #21
Andy4639
Old member
Andy4639's Avatar
That's your opinion sir.
Old 11-19-2019, 10:42 AM   #22
WorkinLonghorn
WorkinLonghorn's Avatar
Re: First run!
Time will tell!
If his oil pressure was 60 (as shown in the video) what possible harm would be done by continuing to idle at that RPM? My understanding is that the 2500 RPM break-in is about oil pressure, unless there is some other mysterious force in play here that can damage a hardened steel cam. Let me know what that condition is so that I can be enlightened.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 11-19-2019, 10:53 AM   #23
geezer#99
geezer#99's Avatar
Re: First run!
Lifter rotation.
Lifters need to rotate to mate with the cam lobes.
You need rpm for that.
Old 11-19-2019, 11:09 AM   #24
geezer#99
geezer#99's Avatar
Re: First run!
And I forgot to mention splash.
The lifters and cam lobes are mostly lubed by oil splash. From the oil draining back to the valley and from the crank spinning.
Not enough of that happening at idle to lube a new cam for breakin.
Old 11-19-2019, 11:23 PM   #25
WorkinLonghorn
Re: First run!
Thanks Geezer, I appreciate you taking the time to school me on this.
