07-03-2019, 05:42 PM | #1 |
BMW & ASE Master Certified
81-87 rear brake circuit have residual check valve stock?
Do 81-87 rear brake line/ circuit have residual check valve stock or is it just a strait shot from the combo valve to rear brake hose?
Thanks Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
07-03-2019, 05:48 PM | #2 |
Re: 81-87 rear brake circuit have residual check valve stock?
All the one's I've worked on were a straight shot after the prop valve. My 89 dually as well.
07-03-2019, 05:54 PM | #3 |
Thanks, I looked and didnt see anything other than what looked to be unions... but wanted to ask just in case
07-03-2019, 06:48 PM | #4 |
Yep.... Unions are all I recall seeing as well.
07-09-2019, 01:20 PM | #5 |
Wouldn't the Residual Pressure valve be located in the outlet of the Master Cylinder for the rear drum brakes?
07-09-2019, 02:21 PM | #6 |
Isn't there a valve in the prop valve that can flip and not give pressure to the rear? Should light up the BRAKE light on the dash. I believe there is a tool to hold it in place while bleeding
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
07-09-2019, 08:34 PM | #7 |
Cpp has a tool to keep the Brake light from tripping... pretty crappy quality, its threads are too small so it feels like it is cross treading.. will it work yeah, will it damage anything no, but I will probably mak a tool out of the old sensor that I probably wont ever use... I picked up cop disc / disc valve finally.. I'll install it in a few weekends.
Just replaced the rear drop brake line.. Sum b, had to replace the brake end fitting as it rounded off. Clint
03-03-2020, 01:30 PM | #8 |
Slightly off topic, but has anyone ever heard of anti-locking rear brakes on an 87? Any information on them? Just noticed it's on my window sticker.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-03-2020, 05:27 PM | #9 |
Rob, 88's had it standard, so it could have been an option in 87. I have never owned or driven an 87 so not sure. Newest square I have had was an 83.
03-03-2020, 06:41 PM | #10 |
Interesting. I don't see any ABS modules, just thought it was interesting on this year model. Thanks Bill!
03-03-2020, 07:18 PM | #11 | |
I don't know if the 1/2 tons had the same valve. If so, GM may have called it anti-lock brakes, as a marketing gimmick. Keith Seymore would know what's meant by "anti-lock brakes", I'm sure.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
