Old 05-11-2020, 09:39 PM   #1
Phungki
Phungki's Avatar
57 gmc hood on a 56 gmc?
The hood that came on my 56 is pretty rough. I have found one off of a 57 that’s in great shape. The guy that’s selling it says it will fit but he could just be trying to sell it. Anyone know if this will fit?
I appreciate your help
Thank you
Phungki is offline   Reply With Quote
Old 05-12-2020, 08:27 AM   #2
Kim57
Kim57's Avatar
Re: 57 gmc hood on a 56 gmc?
It should fit with no problems.
Only difference is the spears in the 57 hood.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 05-12-2020, 09:51 AM   #3
paulspickupparts
As Kim said it will fit . 57 GMC hood is pretty rare with ribs on top and front emblem opening.
Be sure to check that it is not off a big truck.
paulspickupparts is offline   Reply With Quote
Old 05-19-2020, 08:39 PM   #4
Phungki
Phungki's Avatar
Great point. Thank you! What are the measurements I should be looking for?
Old 05-20-2020, 02:39 PM   #5
paulspickupparts
Just measure your 56 hood that you have . Then measure the GMC hood . Compare
Old 05-20-2020, 08:11 PM   #6
mr48chev
mr48chev's Avatar
Hopefully some one can tell you the easy ways to tell the difference between 55/57 GMC /and Chevy small truck/big truck hoods. I'm thinking that as on the AD trucks the 1-1/2 and 2 ton trucks have a slightly longer hood than the 1/2 to 1 ton trucks. I am not positive on that one as the top of the fender line is the same even though the wheel opening is larger.
55/56 Chevy small truck hood will fit too but you loose that GMC hole in the front that some GMC fanatics view as a sacrilege when you do it.
My ongoing truck projects:
Old 05-21-2020, 06:22 PM   #7
dsraven
maybe something in here will have dimensions
http://chevy.oldcarmanualproject.com...esto/56071.htm
https://www.trifive.com/55-59Assy.pdf
Old 05-21-2020, 09:09 PM   #8
mr48chev
mr48chev's Avatar
That is just the 3100 section from GM heritage center 56 truck page https://www.gmheritagecenter.com/doc...olet-Truck.pdf
Scrolling down it there is no info as to if there is a difference in length of the hood or front fenders as there is on the AD trucks. Best is to just measure the old hood down the middle and get a couple of measurements to write down and then measure the 57 hood.
Old 05-24-2020, 04:21 PM   #9
Phungki
Phungki's Avatar
Yeah I’ve got the measurements of my old hood. I’ll compare them tomorrow when I go take a look at the 57.
Thank you all for your input
Old 05-27-2020, 07:27 PM   #10
Phungki
Phungki's Avatar
Yep, exactly the same.
Thanks ya’ll
