06-05-2020, 05:42 PM | #1 |
Choke wires?
So I just picked up an 86 scottsdale with an already installed eddelbrock 1407 carb a d intake. Its a rough start in the mornings because there is no choke installed. While I was wiring my stereo I noticed the choke fuse... so I was wondering if anyone can help me locate these wires comming out of the firewall. I have 2 optional wiring plans for the electric choke I am getting but theres a part of me just wanting figure out where the stock wires are.
06-06-2020, 07:37 AM | #2 |
Re: Choke wires?
Choke wire is normally a dark blue that actually runs to a second oil pressure sending unit. When there is good oil pressure it then allows the 12V to go thru a lt blue wire to the choke. If the second oil pressure sender is missing (which is the case a lot of times), I would just tap off that wire and run it to the choke. By the way, the wire colors are on my 81.
Found a view of the wiring harness
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 06-06-2020 at 07:52 AM. |
06-06-2020, 10:38 AM | #3 | |
Re: Choke wires?
until I saw a choke fuse. There should be 2 wires coming out of the firewall that I can just take and connect without having to do a bunch of extra work. |
06-06-2020, 12:14 PM | #4 |
Re: Choke wires?
The oil pressure switch for the choke is on the driver side of the block, towards the firewall.
if you see a connector hanging with a jumper wire on it, that used to go to that sender. |
