Old 01-09-2007, 12:22 AM   #1
HuggerCST
HuggerCST's Avatar
Tail light fuel filler
Here's my version of a tail light fuel filler. I would have taken better pics of it as it went together, but my fab skills leave alot to be desired. It was fun though, and turned out ok I think. It still needs some fine tuning(rubbing, spring tension, paint, etc), but I'm satisfied so far. Filling the tank will be the real test. Thanks to you guys that helped with ideas and parts.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 01-09-2007, 12:24 AM   #2
ClassicRedneck05
ClassicRedneck05's Avatar
Re: Tail light fuel filler
thoes LED tail lights are them the ones that are like 600 a piece??
ClassicRedneck05 is offline   Reply With Quote
Old 01-09-2007, 12:28 AM   #3
HuggerCST
HuggerCST's Avatar
I got them before the latest price increase, but they were still pretty pricey. They were the only ones that I liked though.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 01-09-2007, 12:29 AM   #4
ClassicRedneck05
how many others are there i love the look at them i have the LEDS that plug into stock locationa nd love them also but i want them more
Old 01-09-2007, 12:41 AM   #5
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
i don't understand why these LED taillights are so expensive. Aren't LED bulbs like a couple pennies each? bread board, some wire, resistors, and you're done.
I'm not saying i could go out and make a set without burning the house, or my truck down, but it just doesn't compute with me how these lights can be so expensive.
I do agree, the full led looks really good.
IvelDesigns is offline   Reply With Quote
Old 01-09-2007, 12:42 AM   #6
IvelDesigns
oh, and your work looks really good too. This is exactly what i am planning to do once i get my tank relocated.
give us some details on what you used for parts.
Old 01-09-2007, 12:59 AM   #7
The Hard Way
Where did you get the full-panel LEDs?
The Hard Way is offline   Reply With Quote
Old 01-09-2007, 12:59 AM   #8
byrd
Union Electrician
byrd's Avatar
Frank's pickmups sells them for like $80 a pair I think.
Nice work I like it
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 01-09-2007, 01:01 AM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
Yeah, what he said!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-09-2007, 01:04 AM   #10
sdkid
I think this calls for a full FAQ writeup. I like this better than the side marker fill. I'm wondering what holds it closed?
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 01-09-2007, 01:08 AM   #11
ClassicRedneck05
Nice work I like it
have a link?
Old 01-09-2007, 01:10 AM   #12
IvelDesigns
if they are the ones i'm thinking of, those aren't full panel. I can see spending $100 or less on LED taillights, but the only set i could find that was a full LED setup was $200 plus whatever cost for the flasher.
unfortunately for me, i like the full plate LED's, so i'll end up forking over the $200 for them.
i guess that's why they can charge that much.
Old 01-09-2007, 01:16 AM   #13
HuggerCST
HuggerCST's Avatar
Sorry for crappy pics.(cheap camera) I used the same marine filler that John Fabris used with his custom filler in FAQ. http://www.westmarine.com/webapp/wcs...allpartial/0/0
The LEDs came from ECE, and are manufactured by board member "Jmac05". Other than that, it's just 1 & 1/2" muffler pipe, fuel hose & clamps, some 3/8 pipe fittings, an old hinge that I had, a throttle spring, sheetmetal, bondo, & primer. If I was to do it again, I'd change a few things like lowering it a half inch or so, and I would change the angle of the muffler tubing to aim straight at the tank filler pipe. This would require removing one or two of the bedside to rear crossmember bolts, but I think it would still be strong enough. Oh yeah, the 2 rubber bumpers are 67-72 fleetside tailgate bumpers. Here's another angle.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 01-09-2007, 01:20 AM   #14
ClassicRedneck05
the ones i seen are way more expensive than that heh im lookin just for a decent set of them
Old 01-09-2007, 01:22 AM   #15
HuggerCST
HuggerCST's Avatar
Kinda hard to explan, but I used a universal throttle spring that is mounted at an angle so that it holds it closed, but when opened, "cams over", and holds it open. You can see it in the inside pic. The other end is attached to the side of the light backing plate. You can see that just below my finger in the LED pic.
Frank (PICKMUP) has changed suppliers, and doesn't sell this brand anymore.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 01-09-2007, 01:37 AM   #16
Aarons72s
That is sweet man. Thanks for posting pics and faqs for us.
Aarons72s is offline   Reply With Quote
Old 01-09-2007, 09:30 AM   #17
Hart_Rod
Hart_Rod's Avatar
Truck's looking good Wynne, can't wait to see it done.
Rob
Hart_Rod is offline   Reply With Quote
Old 01-09-2007, 10:04 AM   #18
HuggerCST
HuggerCST's Avatar
Rob
That makes 2 of us!
Thanks for all the kind words from everyone.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 01-09-2007, 10:32 AM   #19
piecesparts
Parts and more parts
piecesparts's Avatar
Where did the backin plate for the lights come from(the one that hinges down)? Is that part of the LED kit? That came out great, and looks smooth.
Just out of curiosity, where does the spring connect to the light fixture at?
Old 01-09-2007, 11:12 AM   #20
HuggerCST
HuggerCST's Avatar
I cut the bulb bucket out of my original backing plate, welded in some sheetmetal, and smoothed it with bondo. Here's a pic that I edited to show the spring location.
EDIT- Well, you can hardly see it, but I circled it with red just under my finger on the left side.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 01-09-2007, 12:52 PM   #21
big blue 72
That Looks Nice Hugger!
Awesome job!
big blue 72 is offline   Reply With Quote
Old 01-09-2007, 01:08 PM   #22
basketcase
basketcase's Avatar
Very nice installation. No need to apologize. Your craftsmanship and your photos are excellent.
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 01-09-2007, 03:24 PM   #23
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
i think it looks good..i think the ideas for relocating the fill up tube are better than just sticking it under the wheel well to hang there...i like this idea...
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 01-09-2007, 03:58 PM   #24
[ol'Blue]
[ol'Blue]'s Avatar
that is a VERY clean mod.
[ol'Blue] is offline   Reply With Quote
Old 01-09-2007, 04:09 PM   #25
superjeer
superjeer's Avatar
I'll take two. Thanks.
Thanks,
Jere
'72 Cheyenne LWB, Dark Olive.. gone.
Others02 Sienna XLE, 1998 Mercury Tracer Past in order of exit 04 xB RS1, 04 xB BCP, 87 Sciorrco, 97 Safari, 95 Contour, some dodge stratus, 87 Nova notchback, 87 Nova 5 door, 84 Z28. 81 C10 LWB 305
http://www.elmiradhc.com/
http://elmirahockey.com/
superjeer is offline   Reply With Quote
