07-05-2020, 12:32 PM | #1 |
Turn signal fuse keeps blowin', '81 K20 silverado
Turn signal fuse keeps blowin', '81 K20 silverado , last two fuses I put in, turn sigs, worked again then were blown next day after driving. Emergency flashers work. turn sigs dont. Been busy too busy to look into it
Got any ideas? Anyone had this issue? I wonder if the whole switch under the steering wheel is shot... Looked OK when I had steering wheel off a while ago Book says, Back up light is on that 20 amp turn sig fuse too. Any thing else?
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting Last edited by GSP7; 07-05-2020 at 12:37 PM. |
07-05-2020, 03:51 PM | #2 |
Re: Turn signal fuse keeps blowin', '81 K20 silverado
Where to start is anybody's guess, but this tool will help you get started..
http://www.toolaid.com/product/25100 |
07-05-2020, 04:10 PM | #3 |
I would start inspection from tail lights to cab look for burnt or rubbed wires causing shorts to ground
Most tail light harness are a mess from getting hack job trailer lights added The fuse is blowing from overload to the turn signal light circuit |
07-06-2020, 11:28 PM | #4 |
Msgt USAF Ret
Unplug the turn signal harness at the column and check the wires to a good ground for low or zero ohms. if one of them reads continuity then the short is in the column.
If none show low resistance then check all the wires in the other side of the column plug for the same thing. Post back with the results.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
07-11-2020, 08:06 PM | #5 | |
I cant find any issues in the wiring at the back of the truck trailer plug wiring etc or old camper lights wiring 110 degrees out too hot
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
