Old 08-13-2020, 02:12 AM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Adding Rear Sway Bar Question
I have a Hellwig Rear Sway bar and will have to install while truck on ground. Instruction say the weight of the truck needs to be onthe suspension when its installed. If I jack up he truck and put jack stands under the axle is it the same as having the truck sitting on the ground.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 08-13-2020, 04:40 AM   #2
SIXTY9
Re: Adding Rear Sway Bar Question
When I put my QA1 suspension on, and went to set the sway bars I put jack stands on the rear axel and both lower control arms in the front. I also set it as close as I could to ride height.
SIXTY9 is offline   Reply With Quote
Old 08-13-2020, 05:16 PM   #3
SCOTI
SCOTI's Avatar
It's close enough. Try to keep it equal front & rear though. If you put the rear on stands, put some under the front as well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-14-2020, 01:17 AM   #4
Already Gone
Thanks, I kinda thought that might be the right way as then the truck is level withthe weigh on the suspension.
Old 08-20-2020, 10:54 AM   #5
68 P.O.S.
I'm curious as to why you need to put it on jack stands? When I installed my rear sway bar, there was plenty of room with the truck on the ground.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 08-20-2020, 01:08 PM   #6
SCOTI
SCOTI's Avatar
Bigger guy?
Lower truck?
More room to work?
Just 'cause....?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-20-2020, 04:53 PM   #7
Already Gone
Bigger guy?
Lower truck?
More room to work?
Just 'cause....?
Yep, #'s 1-3 and 4
Old 08-20-2020, 05:13 PM   #8
SCOTI
SCOTI's Avatar
Yep, #'s 1-3 and 4
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-21-2020, 11:26 AM   #9
68 P.O.S.
Yep, #'s 1-3 and 4
Touche
