Old 10-23-2020, 08:20 PM   #1
Chvy2NV
Booster or no booster
What’s up guys.. I need some tech advice here. I’m at the point wether to go with a booster or just running manual brakes. I’m running a big brake kit from Baer all around on my 67 with a Baer remaster MC. I’ve seen lots of builds running big performance setups and not using a booster. Need some help from here .. thanks
Chvy2NV is offline   Reply With Quote
Old 10-23-2020, 10:44 PM   #2
Ziegelsteinfaust
Re: Booster or no booster
It's all about the effort of driving your comfortable with.
You could try no booster, and switch if you don't like it. Or even try a small booster which I have been told is a little over1/2 way between the too.
Ziegelsteinfaust is offline   Reply With Quote
Old 10-24-2020, 04:46 PM   #3
LS short box
I run manual brakes on my 67 Nova. Calipers (C5) and the proper sized master and it worked well. As said above just how much you want to press on the pedal. I did the manual brakes because the cam was somewhat big and I didn't have enough engine vacuum.
Old 10-24-2020, 06:13 PM   #4
Rickysnickers
If I were to do it again, I'd invest in a hydroboost system.
Old 10-24-2020, 08:39 PM   #5
Chvy2NV
I’m cleaning up my fire wall and on the fence wether to mount the booster directly to the fire wall or go with Capt fabs shorter bracket. Once it’s painted. I can’t really go back in there to mod the booster mount ..
Old 10-25-2020, 07:58 AM   #6
Axle
Axle's Avatar
Personal preference. My nova came without manual brakes, and I kept it manual brakes when I converted to discs. Its part of the cars personality. (Manual brakes & Manual steering) and when I was still daily driving it I never found it to be a hinderance to be full manual.
Axle is offline   Reply With Quote
Old 10-25-2020, 04:37 PM   #7
LS short box
I did hydro boosts on a couple of projects. Bought them from Paul at Hydra Tech. Worked very well. Some guys are buying them out the junk yard and making them fit. I would got with the Captain Fab booster bracket if you go power. I used one it worked great. I'm running a C5 booster. Here's a pic.
