11-20-2021, 09:59 PM | #1 |
No start???
So this has me stumped.
2004 Silverado 3/4 ton 6.0L automatic 4x4 with 222k miles. Got this truck about 6 months ago for my son’s first truck. It ran and drove but needed some refreshing. Engine work so far. -heads rebuilt by machine shop, we installed w/new gaskets and bolts. -new knock sensors -new intake gaskets -cleaned the injectors -new plugs and wires -oil and filter -exhaust manifolds machined flat w/new gm gaskets Engine went back together, compression seemed good and consistent across all cylinders. Truck starts up fine and we’ve driven it several hundred miles. But, it’s still not running right. Seems like there’s a miss especially after it heats up, say after 5-10 miles driving. I have no check engine lights on. It feels like it’s under powered and running rich, 11.9 mpg. I’ve pulled plug wires one at a time to see if I can find a dead cylinder with no luck. I’ve removed the exhaust heat shield and temped each cylinder exhaust manifold to see if I can find a cool running cylinder, no luck. I’ve checked for vacuum leaks, no luck. I suspect cats might be clogged but haven’t been able to get a good look at them yet. So here’s what has me REALLY stumped. In trying to figure out what might be causing the rough running condition I pull/clean/reinstall the grounds on the frame and block. Grounds I pulled: driver side frame horn (2 wires), batt to engine block (1wire), under driver door (3 wires 2 bolts). I didn’t pull the wire behind the pass cylinder head initially. I try to start the truck and it WONT start! Engine turns over but no start at all. I’ve checked for spark, it’s there. I’ve checked the fuel pump, it’s good. It shows approximately 53psi on the prime and slightly higher during cranking. Battery has been removed and FULLY charged. I’ve tried starting in Park and neutral, no luck. I’m looking for some suggestions. Anything that seems obvious that I’ve done/missed that I can check. I’ll try just about anything. I’m thinking at looking at the cam shaft sensor next. Thx! C3pilot |
11-21-2021, 10:13 AM | #2 |
Re: No start???
Doh…..missed the PCM ground that connects at the battery negative to block connection. Fired right up, still not running great yet still no check engine lights.
11-21-2021, 03:56 PM | #3 |
Moderator
Re: No start???
11.9mpg is not out of line on the LQ4. Mine is averaging 9-11 around town and 12-14 on the highway. Typically 10 City 12 hwy.
It may be time to log some fueling and possibly misfire and knock sensor data to see if you can narrow it down.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
11-21-2021, 07:21 PM | #4 |
Re: No start???
Man that seems low on the MPG! But we’ll keep an eye on it. About to focus on getting the exhaust sorted and go from there. Thx for the numbers!
11-21-2021, 08:56 PM | #5 |
low n' slo
Re: No start???
curious if yours is lifted any or does it have oversized wheels and tires?
my avalanches MPG dropped drastically after a body lift and 20s with 33s.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
11-21-2021, 09:34 PM | #6 |
Re: No start???
No lift and stock tires on mine. How about before your lift and tires? I’m not expecting 20+ mpg, but I am expecting way more than 11-12… Again mine isn’t running right and should hopefully improve when/if I can get it dialed in.
11-21-2021, 09:40 PM | #7 |
low n' slo
Re: No start???
well tbh I never clocked my MPG. but I noticed so much more fuel burned after the wheels and lift.
I also have a 2002 sierra with a 4.8. that one gets waaay better gas mileage but it's completely stock.
11-22-2021, 10:22 AM | #8 |
Moderator
Re: No start???
The engine size and vehicle weight drastically affects the fuel mileage. Not to mention the availability of 6 speed automatics on the 1/2 ton trucks and SUVs at the tail end of the T800 production.
The 4.8 & 5.3 in a 1/2 ton truck will get significantly better fuel mileage than an LQ4 6.0L in a 9600lb GVW 3/4 ton truck. Add in the extra gears and optimized PCM tables for the 6Lxx transmission and you again bump up the mileage noticeably. If you lifted and installed larger tires the speed and odometer are affected quite a lot. Both read lower than actual speed and miles traveled. 3.45 gears with 245/75R16 tires (29.47") changed to 33" tires drops your original 3.45 final ratio down to something roughly similar to 3.08 gears. If I did that with the NV4500 in my GMC the RPMS would drop from 1,103 to go 5mph in 1st gear to 985. You need to change the final drive ratio correction factor in the PCM and adjust the tire size in the ABS computer to compensate for the larger tires. Otherwise the PCM will be using the wrong portions of the fueling and transmission torque reduction tables. Not to mention getting tickets because the speedometer is reading several MPH too low.
And please let us know if and how your repairs were successful. Last edited by hatzie; 11-22-2021 at 10:43 AM. |
11-22-2021, 01:19 PM | #9 |
Re: No start???
my 07 classic 2500 hd 6.0 2wd gets 14-16 unladen and about 11-12 when towing with mild weight. If you have a temp gun shoot the cats when it's up to temp, there should be higher temp after the cat if they are functioning. Also you can watch the O2 data to see if it's swinging. The 02's might just be flat wore out at this point too. Did you do a cam or tune or anything when you pulled the heads, go back with the same 317 heads or change em up? Pull the valve covers and double check torque on the rockers to make sure one didn't loosen up, and feel each push rod to make sure you don't have loose one that maybe is bent.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
11-22-2021, 08:15 PM | #10 | |
Re: No start???
11-22-2021, 08:20 PM | #11 | |
Re: No start???
11-23-2021, 07:26 AM | #12 | |
Re: No start???
11-23-2021, 07:45 AM | #13 |
low n' slo
Re: No start???
I know this might not be related.....
does it take a few cranks, then it turns on? I had to crank mine 2 or 3 times before it would run. I would get random codes, (02 sensors, misfire, etc.) I did a tune up, changed the 02 sensor, fuel pressure regulator, gas cap. couldn't figure it out. turned out to be the fuel pump. the truck just died on me and wouldn't start this time. what happened was the filter sock on the pump completely came apart and the trash of it was being sucked through the fuel system. when I pulled the pump it was completely gone and I can see particles of it everywhere in the gas. new pump, a few new filters later and the engine codes went away and truck fires right up. maybe something to look at?
11-23-2021, 09:03 AM | #14 | |
Re: No start???
Yes check engine light is working, it came on for the bad knock sensors that I replaced. Yes I have scanned for codes but nothing is coming up. I still like the rocker suggestion and will be checking them. I did check the cats and I would say they seem to be bad, lower temp at back of cat. The broken exhaust manifold bolts was what really lead to redoing the heads. Yes….overkill I know to pull the heads for broken exhaust bolts. But….that’s how I roll! Haha. And yes there were exhaust leaks at the manifold prior to doing the heads. I initially used Engine Pro exhaust manifold gaskets and they leaked. Pulled the manifolds off and had them surfaced. Reinstall with same Engine Pro (yes now used for about 2 hours of run time) gaskets and still leaking. Removed the EP gaskets and installed GM original exhaust manifold gaskets. I use new manifold to exhaust pipe ring gasket every time I pull the exhaust apart, this will be my 4th set… the only exhaust leaks I have prior to the cats was at the block to manifold, hence the resurfacing of the manifold and GM gaskets. I know the most logical thing would be replace the cats and O2 sensors. However, I’d really like to have the smoking gun identified before spending the coin to throw a bunch of parts at and pray. But plz keep the suggestions coming! We’ll get it nailed down sooner or later. |
11-23-2021, 09:07 AM | #15 | |
Re: No start???
11-23-2021, 11:27 AM | #16 |
Re: No start???
The fact the cats are cooler at the rear is a pretty definitive test that they aren't doing a damn thing. I would check the rockers, then start looking for cats and quality o2's. Or some long tubes and a y pipe from speed engineering, new front o2's and a tune.... Even a good tune on the stock set up will net some power and MPG gains, especially with free flowing exhaust. But I know you probably don't want to do that, just a suggestion though. Does the 04 have an external fuel filter, if so have you replaced it?
11-23-2021, 12:04 PM | #17 |
Moderator
Re: No start???
2004 doesn't have a fuel filter from the factory. GM stopped putting them in before the 2004 models. Not sure about the 2003 models.
If you have the right Mastercool hydraulic forming dies you can cut a short section out of the fuel line and form the GM fuel line ends to fit the stock 2002 GM fuel filter cartridge. That's still on my to-do list.
11-23-2021, 01:23 PM | #18 | |
Re: No start???
11-23-2021, 03:22 PM | #19 | |
Re: No start???
