03-10-2019, 02:33 PM | #1 |
Evaporator box repair
Hi. I'm new to the site. I'm trying to repair the evaporator box on my '71 Cheyenne. The metal panel on the back of the box is rusted and I need to replace it. The box itself is good, so I was hoping to repair it instead of buying a new box. If anyone knows where I could find one I would appreciate it. Thanks. Tommy
03-11-2019, 10:54 AM | #2 |
Re: Evaporator box repair
Welcome, the metal piece is not replicated to my knowledge. You will need to source a used one. If you become a supporting member you can place a "Want to Buy" on the parts forum. IMO, this is your best bet unless you can find one in a bone yard.
BTW, we all like picks of trucks, post yours up if you can. |
03-11-2019, 11:21 AM | #3 |
Your best bet is to find another box. Way cheaper than trying to repair that one.
Vic |
11-11-2021, 10:18 PM | #4 |
TC71C10, any luck? I'm looking for the same thing.
1972 C-10 Custom Deluxe 468 BBC w/ TCI 400 Trans |
11-11-2021, 11:13 PM | #5 |
Can you post pictures of how bad yours is?
11-12-2021, 12:23 AM | #6 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
11-12-2021, 12:59 AM | #7 |
If you post some pics I will compare them to one I have out of a '67.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
11-12-2021, 07:47 PM | #8 |
Attached pics...Door doesn't shut all the way, maybe from rust? And there is a hole and lots of rust in the metal piece.
11-12-2021, 08:01 PM | #9 |
You could probably restore that if you wanted to. It matters how much of it is surface rust and how much is actually rusted through. On mine I had some parts of it rusted through and I fixed it. I recommend give my thread a read and see if it helps you. https://67-72chevytrucks.com/vboard/...06#post8704506
11-12-2021, 08:50 PM | #10 |
That's awesome! I think it will help alot! Thank you very much! I think I'll drill out the rivets this weekend and see what I can fix.
11-12-2021, 10:54 PM | #11 |
Yes, good. You'll know more about it once you get it apart and perhaps use a wire wheel on the rusty areas. If it's really bad rust but only in a couple of places, clean it up, patch, and paint it. I decided to go with small stainless steel screws and nyloc nuts to put mine back together. The short rubber hose that goes from the fan motor to the housing to help cool the motor is not reproduced and mine was cracked. I used superglue to fix the crack and smoothed on a coating of black RTV over the crack and it came out pretty great.
11-14-2021, 09:40 PM | #12 |
So I'm working on fixing it...
11-14-2021, 11:07 PM | #13 |
Great! That's progress right there.
11-16-2021, 07:46 PM | #14 |
Thanks! I think it's coming out alright. Should be good for another 50 yrs.
