09-14-2014, 02:28 PM | #1 |
I know the pieces fit
'74 Honda Z50
I'll state up front I have zero need for this and it was a bad idea to bring it home with two project trucks already in the drive, but hey, it happened. I found this on craigslist and happened to have empty pockets that day, but I texted it to a friend and he ended up buying it. Several months down the road he'd bought a new house and hadn't started on the bike when he offered it to me for what he had in it.
It didn't run, so it was cheap. The PO had installed shocks off a 70 to get the seat height up but the orginals came with it. Also, the original gas tank was rusted through on one side but my friend had bought a new aftermarket replacement that came with it. So it's all there except for the original tailpipe. It also came with new tires and tubes. Here's what came home. |
09-14-2014, 02:36 PM | #2 |
Re: '74 Honda Z50
The plan was to clean the carb and get it running first then make it pretty. But the original plastic intake spacer was cracked around the bolt holes when I started. So I cleaned the carb, started cleaning on the original shocks, and then I got impatient. So I went ahead and started taking it apart.
09-14-2014, 02:49 PM | #3 |
Re: '74 Honda Z50
I left the forks and swing arm on the frame and broke out the pressure washer. Underneath it had been blue once and green before that. It will be blue again, that was the color tank my friend bought. I also got the tires cut off and the wheel halves separated and run through the blast cabinet and got everything in primer.
09-14-2014, 02:58 PM | #4 |
Re: '74 Honda Z50
Here's where I ran into a snag. The replacement tank was painted the correct '74 Honda blue. All the paint I'm using is rattle can, but I do want it to look right, and the cheapest I could find the correct paint in rattle can was $90-something a can online. I was in Car Quest and saw GM Bahama Blue for $7 a can and decided to run with it. But the tank wasn't going to match, unless...
09-14-2014, 03:04 PM | #5 |
Re: '74 Honda Z50
Yes, I sanded the cracks out of the primer. That was Rustoleum Filler Primer, and it cracks while drying if you lay it on too thick. So I used a regular primer and sanded it smooth with 400 grit and sprayed it with the Bahama Blue. It came out really nice. I have cleared it since this picture and don't have any regrets sanding down a painted and ready to go tank - it really does look nice. I'll get a better pic later.
09-14-2014, 03:10 PM | #6 |
Re: '74 Honda Z50
So, from what I've seen online, the frame is supposed the be black and the forks match the tank and side cover. So, more sanding and painting... The wheels are done with the new tubes/tires installed. The wheels were painted with GM rally silver since I had a few cans.
09-15-2014, 10:05 AM | #7 |
Re: '74 Honda Z50
Pretty neat little project
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
09-15-2014, 10:26 AM | #8 |
1962 C-10
Re: '74 Honda Z50
Too cool!
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
09-16-2014, 09:35 AM | #9 |
Re: '74 Honda Z50
I've still got my 1969 Z50 K1, which was my first motorcycle. It needs to be completely restored, but it'll happen as soon as I can get a couple of other projects done first. My bike is the factory candy red with the candy red/silver tank.
I also have a "barn find" 1968 Honda CT90 that runs like a top. I love vintage Japanese bikes because they are a real flashback to my youth.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
09-16-2014, 02:05 PM | #10 | |
Re: '74 Honda Z50
Thanks guys!
09-16-2014, 08:56 PM | #11 |
I dun gradjiated collij!!!
Re: '74 Honda Z50
I always liked the blue 1st gen Z50s... good lookin little bikes...
CLick the link in my sig, we retro modded my old 79 Z50. Little thing sure surprises people when they see my big a$$ comin... LOL 125CC CDI ignition, Extended forks and swingarm, 10" wheels cafe'd bars and a QA 50 seat,
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! |
09-17-2014, 03:49 PM | #12 | |
Re: '74 Honda Z50
09-17-2014, 04:04 PM | #13 |
Re: '74 Honda Z50
cool little project. be careful those small bikes can be addicting.got a llttle ct 70 myself.keep it to terrorize the neighborhood
10-01-2014, 01:24 PM | #14 | |
Re: '74 Honda Z50
I was waiting for the paint to fully harden before putting it back together, but the front forks were nagging at me. The upper fork bridge has two holes in it for tabs on the upper spring holders, so they won't spin in the forks I guess. Except the tabs on these upper spring holders had cracked off and left the party at some point, and it got to bugging me. And I didn't know how to take the forks apart, so I had to order a Clymer manual. So I'll get to clean these up and reassemble them with the new upper spring holders when they get here. Except now I'm thinking I can paint the and frame better if I don't have to mask anything? Scope creep, I guess, but it'll be nicer for the effort. I hope! |
10-02-2014, 07:24 PM | #15 |
laying low
Re: '74 Honda Z50
That's a good looking blue John. Chrome fenders? A new 40 year old mini is something you don't see everyday. What are you going to do with it when finished?
We used to use those and mini bikes as pit bikes at the drag races.
10-02-2014, 08:36 PM | #16 |
Re: '74 Honda Z50
Thanks Jim. I have no idea what I'm going to do with it, I guess the boys can ride it around the neighborhood if they want. Maybe I should flip it for something I won't care if they scuff up. I don't know, I haven't thought much past "make it shiny and stare at it".
I hosed the fork internals with brake cleaner last night to get the caked-on grease out of the springs then disassembled them. I ran all the individual parts through the parts washer tonight. I've sanded and primed the forks again, I'll try to put down a better coat of blue this time. Fun fun. |
11-22-2014, 04:45 PM | #17 |
Re: '74 Honda Z50
Small update, I got the forks disassembled, cleaned up, and reassembled with new seals and other misc parts where needed.
11-22-2014, 04:59 PM | #19 |
Re: '74 Honda Z50
Got the brakes cleaned up with new shoes. The bearings were in good shape, so I cleaned them up. See pic two, I knew they looked familiar, and the digital caliper read .44. Cool, so out with the nylon bore brush that came with the Kimber, and cleaned up the bearings with Hoppes #9. In the third pic you can see the engine is the focus now. I'm not going to rebuild it, just want it running good. Beer break...
12-18-2014, 11:37 AM | #20 |
I'm just glad to be here!
Re: '74 Honda Z50
Nice little bike.
My wife's Uncle has a few of the Honda Trail 70's. I might have to work on him to sell me one at a fair price for someting fun to tool around on..
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
12-18-2014, 01:42 PM | #21 |
Re: '74 Honda Z50
Thanks man. I ordered a clutch nut removal socket from the local Honda shop so I can check and make sure the clutch discs are in spec before I button it back up mount it in the frame again. If I could get just one weekend that I didn't have to go out of town for something I might could finish this thing.
12-18-2014, 08:21 PM | #22 |
laying low
Re: '74 Honda Z50
The end is in sight now John. All you lack is finishin up. It sure looks like new.
Hmm. I wonder how one of those built into a mini chopper would work or a trike?
12-19-2014, 08:25 AM | #23 |
Re: '74 Honda Z50
Jim, actually I was thinking of a 80's or 90's model with motard tires, a pipe, and mini-apes. I'll have to find a good runner at a cheap price though.
06-14-2015, 11:21 PM | #24 |
Re: '74 Honda Z50
I let this sit a while but have been messing with it again lately. It might even run again. I cleaned and degreased the engine. The side covers are off, I used PB blaster-soaked-red scotchbrite pads on the engine to give it a reasonably even finish.
06-14-2015, 11:33 PM | #25 |
Re: '74 Honda Z50
I'd never messed with a centrifugal clutch before, but it seemed like a good time to figure it out, at least well enough to put new friction discs in. The steel shims looked great and were reused. All Honda parts... I masked off the center section and gave it a new coat of satin black. I cheated on the side cover and painted it with Chevy rally silver since that's what I have and still dig it.
