Old 02-25-2022, 07:53 PM   #1
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Anyone using the DIY4X Engine Cross member?
Is anyone here using the 2nd design DIY4X engine cross member with the drop out center? I have used the 1st design with the solid tube and it worked good. Thinking about ordering the new style but read in another forum about some fitment issues.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 02-25-2022, 08:06 PM   #2
BLAZERMAN
BLAZERMAN's Avatar
Re: Anyone using the DIY4X Engine Cross member?
I just saw the other cross member post.pop up after I posted this. Guess I should mention this is for a basic old small block engine. What I had read was something about having to use shims under the motor mounts.
Old 02-26-2022, 12:50 PM   #3
GMule
Using this crossmember on my K20 project and it worked out great. Plus it helped facilitate sliding the SBC forward to allow for a 700R additional length.
GMule is offline   Reply With Quote
Old 02-26-2022, 06:37 PM   #4
GMC71k20
I have one in my 71 k20 with a sbc and it did require a lot of force (hammer, pry bar) to install and the drop-out section is under alot of pressure and requires large screw drivers and punches to get everything to line up
GMC71k20 is offline   Reply With Quote
Old 02-27-2022, 12:03 PM   #5
GMule
Definitely could see this happening. My install had the benefit of having the front crossmember removed.
Old 03-03-2022, 08:51 AM   #6
jaros44sr
jaros44sr's Avatar
Put the original design in first, called DIY, and asked him if he could put flanges on it, to make it a 3 piece design.
I've had to change oil pan a couple times, and. It sure makes it easy, just mark the front of the center section as it may bind, no problems with reassembly with just the motor mounts holding up the engine
Hardest part was getting the old cross member out
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-03-2022, 09:10 PM   #7
BLAZERMAN
BLAZERMAN's Avatar
Thanks for the info guys! I was going to try and find a used 1st design but think I'll go ahead and order the 2nd.
