04-09-2022, 12:06 AM | #1 |
GM made with FORD paint
Recommended 5/7 Static Lowering Kit for 72 GMC with rear leafs
Looking all through old board posts and just keeps coming up with the now rebranded ECE kit that no longer exist.
1972 GMC Custom 1500, 2WD LWB, 1970 chevy impala SS 350 c.i., shaved door handles, Ford Paint (portofino blue), blue underglow, and much more. 1998 GMC Sierra 1500 ext. cab, 2WD SWB, 305 c.i. all original 165,000 miles and still strong (daily driver) |
04-10-2022, 04:05 PM | #2 | |
Re: Recommended 5/7 Static Lowering Kit for 72 GMC with rear leafs
Rear flip info: http://67-72chevytrucks.com/vboard/s...d.php?t=577529 The difference to be aware of is the early GMC leafs are 2.25" vs later 2.5" width so standard flip kits are of the 2.5" width variety. There was a rumor that Holley bought the ECE line of products but I'm not sure how valid the info is. Holley has been gobbling up A LOT of companies though so you might see if they're offer suspension stuff for your model.
04-12-2022, 12:03 AM | #3 |
I think I ended up grabbing a flip kit for a square body for mine since it really doesnt matter. The issue youll have is for the drop shackle kit. That I think I just found on ebay when I did mine. Havent had any issues with my setup.
70 GMC LWB Fleetside, 402BB, TH400 90K original only cost $50. |
04-12-2022, 08:35 AM | #4 |
This is my feeling as well. If doing a flip kit, any flip kit set-up should work fine. When dealing w/lowered leaf packs or shackle/hanger pieces, that's where issues arise because of the 2 different spring widths.
Tags |
72 gmc lowering kit |
