Old 04-23-2023, 11:58 AM   #1
Yamariv
Yamariv's Avatar
Adding Power Brake Kit - What fitting goes into intake for vacuum?
Just ordered a power brake kit for my truck. The vacuum line goes to the intake where the orange plug is, correct? What fitting would go in here, I'll have to try and find one.
1971 Chev C10 - 250ci L6 w/3 speed on the floor
Upgrades: Power Steering
3 Core Radiator
7 Hole Gauge Cluster
Power Brakes (Incoming!!..)
1971 350 (Incoming!!..)
Yamariv is offline   Reply With Quote
Old 04-23-2023, 12:29 PM   #2
geezer#99
geezer#99's Avatar
Re: Adding Power Brake Kit - What fitting goes into intake for vacuum?
Yup!
Right there.
With a hose look for a barbed fitting like in this link.
https://www.amazon.ca/Anderson-Metal...689575706&th=1
Old 04-25-2023, 09:52 AM   #3
Yamariv
Yamariv's Avatar
Originally Posted by geezer#99 View Post
Yup!
Right there.
Just saw this update now, thanks! So just to be sure, what thread size should I be ordering? Is the intake safe to use thread sealant on install?
3 Core Radiator
Old 04-25-2023, 10:31 AM   #4
geezer#99
geezer#99's Avatar
Pull the plug out and take it with you to the parts place and match up the threads.
Those barbed fittings are available in most hardware stores like Canuck tire, Home Depot, etc.
An alternate fitting you could use is a vacuum tree.
Like this example.
https://paceperformance.com/i-648576...m-nipples.html
A good source for vacuum trees is the wrecking yard. Look on Ford trucks. They always have multi ports on them.
Old 04-25-2023, 12:36 PM   #5
72SB
That plug is NPT. Not sure if its 3/8 or 1/2". Auto part stores or Amazon has them.
I used that port for my PB. I just used Teflon tape on threads.
72SB is offline   Reply With Quote
Old 04-25-2023, 04:02 PM   #6
Yamariv
Yamariv's Avatar
Like this example.
Thanks Guys, Part Guy hooked me up today!! Turns out it was a 3/8's plug
3 Core Radiator
