Old 11-22-2007, 12:21 PM   #1
blue betty
67 E-brake removal
Good morning everyone from the great white north. I noticed that my e brake is seized. The front cable fom the handle through the fire wall and the frame is stuck. I'm not sure how to remove it. where it goes through the frame? any suggestions?
1967 GMC Fleetside. (Betty)
1985 Chevy Shortbox 4X4.(Freddy)
blue betty is offline   Reply With Quote
Old 11-22-2007, 06:41 PM   #2
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: 67 E-brake removal
Hello,
these pictures should help:
where the cable goes thru the frame
cable clip on the frame in wheel well
backing off the equalizer nut
cable where it attaches to hand lever
new cable where it goes thru frame
I thought I had some of the new cable after installation, but I don't. The easiest way to remove the old cable at the frame is to break off the little spring fingers.
Hope that helps!
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
Last edited by oldgold70c10; 11-22-2007 at 06:43 PM. Reason: so pictures would show
oldgold70c10 is offline   Reply With Quote
Old 11-22-2007, 07:36 PM   #3
blue betty
Smile Re: 67 E-brake removal
Thanks for the great pictures and info. Very very helpful. Wasnt to sure how it came off. Thanks for all the help Ireally appreciate it.
Old 07-03-2022, 12:34 PM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
How do you hold down all those clips at the same time to get it out of the hole in the frame?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-03-2022, 12:52 PM   #5
Grumpy old man
Grumpy old man's Avatar
Use a small hose clamp to compress the fingers when removing .
Old 07-03-2022, 01:06 PM   #6
LostMy65
LostMy65's Avatar
Great! I was also thinking of sliding a nut that is just the right size over it.
Old 07-03-2022, 08:31 PM   #7
LostMy65
LostMy65's Avatar
Yep, hose clamp worked. Thanks
