10-14-2010, 07:31 PM | #1 |
brake pedal assembly removal
I am gonna remove my brake pedal assembly outta my '71 Burb. What all is involved in this......looked up there and looks like a lot of crap to remove. I need to remove so I can install my hydroboost system. I am pretty sure I gotta pull the huge black bracket that the pedal is connected to and I believe it connects to the firewall....and I believe the studs on the outside firewall is connected to it also. Anybody got any advice and/or pics.....
10-14-2010, 10:49 PM | #2 |
Re: brake pedal assembly removal
ttt
10-14-2010, 11:02 PM | #3 |
The Older Generation
The nuts that hold the master cyl on have to be removed. You should be able to just pull the master away from the firewall instead of completely removing it. You don't mention if it is manual or auto trans, or manual or power brakes and that all makes a difference. You have to drop the steering column down. I think there are two bolts that hold it to the bottom of the dash and one up under the dash. It's been quite a while since I removed one so I'm a little fuzzy on it. LockDoc
10-15-2010, 05:30 AM | #4 |
Here is a picture of the bracket by itself. Only picture that I have but it shows the front bolts.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 10-15-2010 at 05:31 AM. Reason: Added wording |
10-15-2010, 09:37 AM | #5 |
Do you mean you are just adding power brakes? If so, there is a mechanism that bolts to the firewall and the master/booster combo bolts to that. I used a bendix vacuum booster. Getting the rod that hooks to the brake pedal adjusted was the worst part. The bracket in your picture is exactly like mine on my '71 and I did NOT have to remove it.
10-15-2010, 10:53 AM | #6 | |
The Hydroboost that DBear is installing is a completely different animal. I will post a link to an article on it in a different post. LockDoc
10-15-2010, 10:53 AM | #7 |
Here is a good thread on a hydroboost install. http://67-72chevytrucks.com/vboard/s...d.php?t=223491 LockDoc
10-15-2010, 08:30 PM | #8 | |
10-15-2010, 10:47 PM | #9 |
There is a bolt on the right side of the bracket by the tube that goes through the brake pedal. You have to remove the bolt and pull (pry) the pivot tube out of the bracket. The pedal will then pull down out of the bracket. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 10-15-2010 at 10:55 PM. |
01-08-2020, 11:48 PM | #10 |
That pedal mount looks very similar to the one on my 66, which is very good news!👍
01-09-2020, 12:23 AM | #11 |
Also, if anyone is interested in hydroboost, I found that the adapter plate from an 85 C30 was a direct fit to the firewall on my 66 GMC
07-12-2022, 12:41 AM | #12 |
Where can I find a replacement brake pedal assembly? The one in my truck has severely rusted master cylinder mounting studs that are severely corroded.
