11-30-2022, 12:24 AM | #1 |
GearWrench 120T Ratchet Wrenches
I just purchased a 4-piece set of GearWrench 120 tooth ratchet wrenches. I already had a dozen or more ratchet wrenches, but when I saw these I had to have them. Here's what I've discovered so far:
The 120 tooth ratchet operates as smooth as silk. There is absolutely nothing clunky about it. The ratchet is constructed with a double 60-tooth structure, so it doesn't suffer from the weakness that high tooth count ratchets sometimes do. That gives it a 3 degree arc for engaging the next tooth; it barely needs to move to engage. It also has almost zero back drag, which means that you can turn fasteners that are very loose and would normally require a second hand. The overall construction seems very solid and they have a lifetime warranty. The tools are made in Taiwan. For the $150 I paid with shipping, I consider it a very worthwhile purchase.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
11-30-2022, 02:23 AM | #2 |
Re: GearWrench 120T Ratchet Wrenches
I have two sets of Gearwrench flex head ratcheting wrenches, metric and SAE. I really like them.
11-30-2022, 07:23 AM | #3 |
Nice set.
I like those ratchets. One of those gearwrenchs save the day last week. It was the only way I could easily take a bolt out without taking an AC line off. I did not want to lose the freon.
12-01-2022, 11:33 AM | #4 |
I bought the same set a few months back. I look for reasons to use them I like them so much!
