02-08-2023, 06:53 AM | #1 |
The LuvShack Garage
Flip Kit Question - 88 C3500
Are Shock Extenders needed since axle is closer to the frame ???
*Ordered some, not even sure they are right, and may not need. Trying to button up all the parts so I can 6/8 this thing real soon.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
02-08-2023, 08:27 PM | #2 | |
Re: Flip Kit Question - 88 C3500
You want shock mounts extenders.
02-09-2023, 06:39 AM | #3 |
The LuvShack Garage
Thanks, appreciate the feedback...
02-16-2023, 11:24 AM | #4 |
Correct, even with shorter shocks I still needed the extenders after the axle flip.
02-18-2023, 12:33 PM | #5 |
The LuvShack Garage
Have any pics? (No directions in the box)
02-22-2023, 10:38 AM | #6 |
You'll want the lower shock extenders as well as upper shock relocators.
Weird GM design thing.... the driver side shock dimensions @ the frame vs the rear end are different vs the pass side (about a 4" difference). On my 3/4 ton (HD/8-lug), I used the lower extensions, modded the pass side upper placement (to be closer to the driver side dimensions), & got the Bell Tech upper relocation brackets. http://67-72chevytrucks.com/vboard/s...d.php?t=817106 The flip yields an easy 8" of drop. I added lift shackles to dial in a 5/7 drop so it's still useable.
02-24-2023, 07:11 AM | #7 |
The LuvShack Garage
