04-24-2023, 08:35 PM | #1 |
Rain gutter/visor seam trim
Is there a piece that covers the seam between the front rain gutter/visor and the curved transition near the A pillars on both sides? There seems to be a pretty good gap in the edge of the gutter between the two. I wasn't the one that cut the old rotted stuff out and Ive looked and searched and don't see anything mentioned in the LMC catalog either.
04-24-2023, 10:07 PM | #2 |
Re: Rain gutter/visor seam trim
I think there was just some sort of seam sealer used back then that rotted away after many years. If not, it was just made with the gap because these trucks were still basically tractors with windows
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
04-25-2023, 07:27 AM | #3 |
My buddy who's helping me with the work swears there was a strip of metal like a clip that was folded over the edge that connected the front piece with the side piece. It seems there's another one just like it where the side meets the rear. For now I just seam sealed it until I can find it. Or I'll just leave it as is.
04-25-2023, 08:46 AM | #4 |
Here is the clip, I also had to build one myself.
Roughly like the sketch. The clip also goes under the gutter and is spot-welded there.
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
04-25-2023, 04:03 PM | #5 |
Yup. That's it. I guess I'll just make one then.
04-26-2023, 12:02 AM | #6 |
Ah, my bad, I didn't fully understand what you were asking about. I haven't seen that little piece remanufactured by any of the typical suppliers. Heck, not even the correct 60-63 inner panel is being reproduced.
05-08-2023, 08:56 PM | #7 |
They would probably sell a bunch if they repopped them. I'd a bought one a couple weeks ago
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
