Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 12-22-2023, 04:32 PM   #1
CSHADES
CSHADES's Avatar
1941 clutch
i have a customers 1941 chevy 3/4 ton long bed in the shop for an engine. i figured since i was doing that i might as well replace the clutch. easier said than done, this one has a 11 inch disc & pressure plate, every one i looked up was wrong when it got here. it is very odd with a 9 bolt pressure plate, 10 spline disc. i lucked out with the pressure plate, there is a local guy that has been buying out old stock from dealerships and he had the one i needed. so that left the disc, the only place that listed it was chevs of the 40s and they wanted $250 for a rebuilt one. i decided to research by dimensions and i found a new LUK disc from napa that was almost exact. the part# is nd4187 fits a bunch of Jeep things and is less than $100 for a brand new disc. I hope this helps someone that is looking for this.
CSHADES is offline   Reply With Quote
Old 12-23-2023, 10:51 AM   #2
VWNate1
VWNate1's Avatar
Post 1941 Chevy Light Duty Clutch
It should be a diaphragm typ of clutch cover .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 12-26-2023, 10:14 AM   #3
CSHADES
CSHADES's Avatar
Re: 1941 clutch
it is a diaphragm clutch but uses 9 bolts to hold it to the flywheel instead of the usual 6
Old 12-26-2023, 11:00 AM   #4
VWNate1
VWNate1's Avatar
Post Re: 1941 clutch
Gotcha ;
It's usually slightly larger, the light trucks and commercial vehicles had a slightly larger diameter .
-Nate
Geezer
