09-27-2021, 11:23 AM | #1 |
Rear Passenger Door Won't Open
All other doors work as they should, all door panels are removed so that isn't the cause. I can't get the damn thing to budge it never had the lock pull but always worked with power locks interior/exterior handles are working just not opening. I've oiled the striker as best I could get to it, still nothing. The lock pull is cut down low and loose inside door. But they worked fine when I got the power lock button.
As always thanks in advance for your assistance! It is greatly appreciated! '90 crew cab
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
09-27-2021, 08:18 PM | #2 |
Re: Rear Passenger Door Won't Open
It had to see since you have all panel off the doors. The one that opens. That door check the three rods move the out side rod for the out side handle the long in side is the inner door handle up and down by the latch is the lock rod. If your looking in the area rod of the door check to make sure there moving and hooked up when you test each one if it moves. But it is not hook up on both side the clip broke or feel off one of the ends. compare to the door that not opening. To get the door open to work on take a pry bar or screw driver that reaches the latch lever hold as best you can. I forget now for sure I think it down but could be up. then as you do that pull open door
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
