Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Engine and Drivetrain
Old 10-30-2006, 03:55 PM   #1
my67C10
my67C10's Avatar
spark plug wire placement
i know that the firing order is 18436572 . the distribuator looks like this
-------------------------------0--0
-----------------------------0------0
which one is #1
---------------------------0---------0
what numbers are the cylinders?
my67C10 is offline
Old 10-30-2006, 04:31 PM   #2
jooooooe
Re: spark plug wire placement
looking at the engine from the front, the right hand side is the odd bank 1-7, the left side is the even bank, 2-8.
wouldn't it be great if we where all like Forrest Gump.?
jooooooe is offline
Old 10-30-2006, 04:32 PM   #3
st1x10
st1x10's Avatar
8 7
6 5
4 3
2 1
Front of Motor
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline
Old 10-30-2006, 04:32 PM   #4
my67C10
my67C10's Avatar
i found the cylinder numbers, but i dont know which outlet on the distribuater is #1
my67C10 is offline
Old 10-30-2006, 08:31 PM   #5
Boise69
The Hammer Man
Boise69's Avatar
Is an ACCEL HEI cap any different? The cap in the diagram is very helpful, i hope its the same as my HEI because i took all the wires off and the tape fell off the wires because of the cold
Boise69 is offline
Old 10-30-2006, 08:37 PM   #6
st1x10
st1x10's Avatar
The Accel should have the same firing order. That diagram is nice by the way. Props for that.
2002 Chevy S10 V6
st1x10 is offline
Old 11-29-2006, 05:47 PM   #7
bryanw1968
bryanw1968's Avatar
#1 can start anywhere on the cap b.t.w......
As long as the motor is at TDC and the rotor is pointing towards the spark plug wire that is going to the #1 cylinder it doesn't matter. People just usually point the rotor approximately towards the #1 piston. If that makes any sense.
bryanw1968 is offline
Old 11-29-2006, 05:47 PM   #8
krue
Designated A-hole!
krue's Avatar
Yeah, btdt, but there is a "factory" position for #1 and the wires fit better if you use it (I just found this out recently).
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline
Old 11-29-2006, 05:52 PM   #9
bryanw1968
bryanw1968's Avatar
Of course.....But when I first started out on motors a long time ago I thought that the rotor HAD to be pointed there for a reason. It used to make my brain hurt
Old 11-29-2006, 05:57 PM   #10
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
HOw do you know when the motor is TDC and also how do you get it to that point if its not? Also which way should the Rotor be pointing?
Angelse68cal is offline
Old 11-29-2006, 07:31 PM   #11
krue
Designated A-hole!
krue's Avatar
With the #1 cylinder at TDC on the compression stroke (easiest way to do this is with the drivers side valve cover off and #1 spark plug removed, rotate the engine (starter if your quick or with a socket on the harmonic balancer bolt) until the piston is at the top of it's stroke with both valves shut. Then insert the dizzy with the rotor pointing toward the steering wheel (or thereabouts) because as the gear on the bottom meshes with the cam it will rotate. This is going off memory because it's been a while since I did this.) You will probably have to try several times to get a feel for where you need to start. Don't forget there is adjustment in the dizzy itself so don't get worried if it doesn't look exactly right to start with.
www.daveramsey.com
krue is offline
