09-16-2019, 11:10 PM | #1 |
PBFab frame stiffener
Has anyone used the PBFab frame stiffener with a RideTech strongarm rear coilover setup?
Posted via Mobile Device |
09-19-2019, 09:08 PM | #2 |
Re: PBFab frame stiffener
Bump
09-26-2019, 01:42 AM | #3 |
I don’t have the frame stiffner but I do have the rest of the PB front and rear suspension. What are your concerns or questions?
Customization is what you want it to look like -- not what other people think it should look like |
09-26-2019, 11:20 AM | #4 |
I’m wondering if the ride tech trailing arms will mount to the trailing arm mounts on the frame stiffener. Like is the spread on the mounts the same?
09-26-2019, 07:15 PM | #5 | |
That being said, if one or the other required custom rear-end mounts to compensate for some sort of design change, then I would be hesitant. If both set-ups work w/a factory T/A rear end, I would think you'll be ok.
