Old 04-06-2016, 05:11 PM   #1
50dude
350 swap
by using the stock 350 rear dump exhaust manifold do these run into clearance issues also with putting 350 in AD
50dude is offline   Reply With Quote
Old 04-06-2016, 07:48 PM   #2
mphudak
Re: 350 swap
Might want to post up more about what your suspension set up is. Guessing stock, but dont' want to assume.
55.1 GMC Suburban Hydramatic
mphudak is offline   Reply With Quote
Old 04-06-2016, 08:01 PM   #3
Coach529
Coach529's Avatar
Re: 350 swap
This has been covered a ton, a search will get you days of reading....
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 04-06-2016, 08:47 PM   #4
50dude
Re: 350 swap
Old 04-06-2016, 08:49 PM   #5
50dude
Re: 350 swap
Every body talks about ram horns and such just haven't read anything about stock rear dumps thought it was simple question
Old 04-06-2016, 11:40 PM   #6
tmoble
Re: 350 swap
there's clutch linkage and stuff. need to know what you're working with to give a decent answer.
tmoble is offline   Reply With Quote
Old 04-07-2016, 01:11 PM   #7
_Ogre
_Ogre's Avatar
Re: 350 swap
to add to tmobile: usually you have steering box and brake pedal in that area
center dump rams horns or block hugger avoid all these areas
shop air compressor timer
Old 04-07-2016, 04:54 PM   #8
50dude
Re: 350 swap
Thank you OGRE
