Old 08-09-2018, 09:24 AM   #1
bj383ss
bj383ss's Avatar
Emblem Restore
So I saw this done on a squarebody emblem a couple of years ago and finally got around to trying it on mine. It worked much better than I thought. Should last a lot longer than paint.
I had a set of 66 badges from the Junkyard for wall art so I tried the process on them first.
20180805_101846 by bjohnson388, on Flickr
I cleaned it with steel wool first. Here is the resin I used. Bought it at Hobby Lobby.
20180805_102317 by bjohnson388, on Flickr
You mix the two equal parts until there is not more swirls.
20180805_102629 by bjohnson388, on Flickr
I originally was going to use ink from the sharpie pen. But I couldn't get it to release any ink and sense I already had the resin mixed I grab the spray paint I used on my wheels and used that instead.
20180805_103152 by bjohnson388, on Flickr
20180805_103005 by bjohnson388, on Flickr
It self levels. So I make sure you have it on a level surface while it dries.
20180805_103611 by bjohnson388, on Flickr
Cleaning my 64' emblems I notice one of them still had flashing from where it came off from plating.
20180805_105126 by bjohnson388, on Flickr
20180805_113808 by bjohnson388, on Flickr
20180805_113819 by bjohnson388, on Flickr
20180805_113825 by bjohnson388, on Flickr
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 08-09-2018, 09:47 AM   #2
66K20
66K20's Avatar
Re: Emblem Restore
Nicely done!
Brett | 1966 K20 - 292/SM420/T221
66K20 is offline   Reply With Quote
Old 08-09-2018, 10:07 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Emblem Restore
I like it, great write up and pics - thanks.
Old 08-09-2018, 10:22 AM   #4
vin63
It's Better With Nitro
vin63's Avatar
Re: Emblem Restore
Very cool!
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-09-2018, 10:53 AM   #5
Mullda
Mullda's Avatar
Re: Emblem Restore
Great idea. I'll try that with mine also. They really need it.
Mullda is offline   Reply With Quote
Old 08-09-2018, 12:11 PM   #6
Bears63
...just another truck junkie..
Bears63's Avatar
Re: Emblem Restore
That looks fantastic. I will definitely give this a go for the badges on my '63.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 08-09-2018, 12:44 PM   #7
The Rocknrod
Moderator
Re: Emblem Restore
What is the resin again? Info?
Old 08-09-2018, 11:04 PM   #8
Railroader
Railroader's Avatar
Re: Emblem Restore
Did you put anything on the chrome area of emblem? Was steel wool all you used in cleaning?
Railroader is offline   Reply With Quote
Old 08-10-2018, 07:26 AM   #9
bj383ss
bj383ss's Avatar
Re: Emblem Restore
Originally Posted by 66K20 View Post
Nicely done!
Thank You
Thanks Rod
Originally Posted by vin63 View Post
Very cool!
Thank YOu
Thank You. Mine were pretty sad looking to begin with.
Thank You. It was way easier than I thought.
Rod here is the box.
20180810_061504 by bjohnson388, on Flickr
Just cleaned them with metal polish after and buffed.
Before picture of one.
20180520_135004 by bjohnson388, on Flickr
Mocked up one on the truck.
20180809_093806 by bjohnson388, on Flickr
Bret
Old 08-10-2018, 11:03 AM   #10
66C10LB
Re: Emblem Restore
Thanks for the tips. I will have to try this on my 66.
66C10LB is offline   Reply With Quote
Old 08-10-2018, 11:13 AM   #11
djnordeen
Re: Emblem Restore
Great Idea, Very nicely done
djnordeen is offline   Reply With Quote
Old 08-10-2018, 11:16 AM   #12
jchav62
1962 C-10
jchav62's Avatar
Re: Emblem Restore
Looks killer!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 08-10-2018, 04:19 PM   #13
The Rocknrod
Moderator
Re: Emblem Restore
Originally Posted by jchav62 View Post
Looks killer!
Ya that would even make new ones look better.
Old 11-13-2020, 07:13 PM   #14
The Rocknrod
Moderator
Re: Emblem Restore
I just got a new pair of fender emblems heading my way and I'm thinking I might do this, I'll keep ya posted.
Old 11-13-2020, 09:57 PM   #15
roll_the_dice
roll_the_dice's Avatar
Re: Emblem Restore
This is brilliant...I work with 2 part resin every day and never thought to do this...I will do it now though!
Here is a tip...after you put the resin on the part...hit it with a propane torch or a heat gun for just a few seconds. It will pop any air bubbles that are on the surface or hiding under.
roll_the_dice is offline   Reply With Quote
