Old 09-26-2020, 06:13 PM   #1
kcstreetracer
Trying to identify what yr seat frame this is
Can someone explain how to identify what yr seat frame i have? I've heard there are differences, trying to order new foam and cover but I don't know what exact yr the frame is. Only that its a 67-72. Cant upload pics of it for some reason, it says a security token is missing. Thank you
1968 C10 SWB, mild 355,5/7 drop, budget frame off, piecing it back together!
kcstreetracer is offline   Reply With Quote
Old 09-26-2020, 08:47 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Trying to identify what yr seat frame this is
That generally means that the picture is too big. I size all of mine down to 1150 pixels wide.
See if this thread helps with the seat ID:
https://67-72chevytrucks.com/vboard/...d.php?t=510997
LockDoc
Leon
Old 09-26-2020, 10:06 PM   #3
tdangle
tdangle's Avatar
Are there differences in the frame or is the cover specific to the foam?
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 09-27-2020, 12:54 AM   #4
Astro-Balls
Astro-Balls's Avatar
Does the seat back fold forward? or is bolted downed not fold?
http://www.americancushionind.net/pr...chevy-gmc-kit/
67-72 Chevy truck cushions came in 5 models
6″ thick molded foam bottom with molded back. (#CT6972)
6″ molded foam bottom/coil spring back with thin pad.
Coil spring bottom with thin pad/molded foam back.
Coil spring bottom and back. Thin pad on both.
Some Canadian truck seats have been reported to be 1-2″ longer than American seat frames.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 09-27-2020, 03:54 PM   #5
HO455
HO455's Avatar
This thread has information on the difference in seat frames and foam. You can identify the differences by looking at the spring patterns for regular and full foam seats.
This and LockDoc's link to the seat mounts will get your seat identified. Although it is not unheard of for some one to change the mounts. Look close as there are subtle differences in the 69/70 frames and the 71/72 frames that will make identification positive.
https://67-72chevytrucks.com/vboard/...d.php?t=804108
RIP Bob Parks.
Old 09-27-2020, 04:04 PM   #6
mr48chev
mr48chev's Avatar
On the "security token" Try selecting and uploading one photo, then click on and upload a second photo, and so on until you get what you want to upload or get to the 5 total. My internet is so slow that I have to do that most of the time . Sometimes I might be able to upload 2 at a time before it times out but I haven't been able to upload 5 at a time at home.
My ongoing truck projects:
