engine bay wiring
i have a loom of wiring that i have no clue where it goes and ihavent found a very helpful diagram yet. basically i have a heavy red and pink, a small guage pink and a few other small ones, im assuming ones for starter, choke, and probably my guages just need to know whats what because i dont need any of the guage ones.
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: engine bay wiring
At first I thought it was the TCS harness (transmission controlled spark) an emission system, but the wiring colors don't match. It might be the harness for the AC if you have or had one.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
A heavy gauge red indicates the main AC harness feed but could also be from the alt or firewall junction. A heavy gauge pink is HEI BAT feed and the smaller gauge pink if it has a black stripe is typically the fuel tank level sensor feed-assuming this is all under hood wiring.
ill take a picture
Any pics yet....? Or did you figure it out?
Looks like a red alt. wire (plug), red alt. main charge lead, white Ign sw. alt. lead, yellow looks like its scabbed in for electric choke? Black wire not sure. Looks like there's been a few mods to the OEM harness to me. There is a yellow lead that goes to the blower motor resistor on AC delete trucks 73-80....possibly the PO used that for the choke?
my alt is already plugged in minus the lead to the battery, white would go where then? the starter?
yellow i assumed was choke but i could be wrong, what about the elctrical taped pink wire? thick red goes to alternator as well? black i have no clue either when i get a battery tapped in i was gonna see if it has power to it otherwise ill ground it or tape it off. and yea obviously the previous owners had their way with it just trying to figure it all out for myself now |
ouch! i'd rewire that truck before it burns to the ground
seriously, that would be a good winter project ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
