Old 09-18-2012, 11:48 PM   #1
74 stepside
74 stepside's Avatar
Project "Barney"
Guess Ill start a build thread. Starting off with my 74 Cheyenne Super, its been sitting for 11 years. I just built a 350 mild with comp cam and 2.02 heads. I have a t400 trans now, but Im getting a 700r4 soon. Was going to do a BBC, but I changed my mind. Just rebuilt the front suspension with new ball joints, new bushings and new drop spindles with cross drilled rotors. Swapped out the rear springs for newer ones and a flip kit. Drop will be a 5"/7".
74 stepside is offline   Reply With Quote
Old 09-18-2012, 11:53 PM   #2
74 stepside
Re: Project "Barney"
Then I decided to pull everything apart and ordered some new body mounts, motor and trans mounts too.
Old 09-18-2012, 11:56 PM   #3
74 stepside
Pulled the cab off and started cleaning the frame. Next will be to do a notch then paint the frame with POR15 semi-gloss.
Old 09-19-2012, 12:04 AM   #4
74 stepside
Couple more pics.
Old 09-19-2012, 12:13 AM   #5
74 stepside
The battery destroyed my passenger side front fender, inner fender, and lower part of core support. Found a guy on craigs list who has a yard full of parts. Got a fender, inner fender, core support, and a 1 ton sway bar all pretty cheap.
Old 09-19-2012, 10:10 AM   #6
Pop's C-10
Pop's C-10's Avatar
nice looking motor
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 10-11-2012, 02:56 PM   #7
74 stepside
Got some more new parts in the other day. Been working on wire wheeling the frame. Should be doing my C-notch this weekend then the frame will be ready for the semi-gloss Por15. I recieved my Western Chassis 2 1/2" drop springs to go with my 2 1/2" drop spindles. Lower swaybar brackets and a 1 1/4" swaybar from a 1 ton dually to replace my stock 1 1/16" swaybar.
Old 10-14-2012, 11:26 AM   #8
RRC
RRC's Avatar
Originally Posted by coops714x4 View Post
Bob, GREAT work!! I am impressed with your patients and dedication to "restore" this project. Its gonna look GREAT when done (kinda looks like frankenstein now tho LOL) it will get there tho. I'm glad mine didn't need all the work your is, man this has truly been a BIG job, but it will be worth it in the end. keep up the good work. Coop
Originally Posted by Rusbuilt View Post
I can't wait to see this thing all together!!
Originally Posted by 74 stepside View Post
RRC that truck is beautiful.
Looking good,this brings back memory's ! I did my truck in 2000.
sorry about the crappy photo it's a pic of a picture,no digital photo back then
RRC is offline   Reply With Quote
Old 10-14-2012, 11:30 AM   #9
RRC
RRC's Avatar
Posted via Mobile DeviceI'm having troubles posting 2 pictures in one post
Old 12-20-2012, 10:51 PM   #10
74 stepside
POR15 didnt turn out how I liked. Didnt like the satin either. Decided to powdercoat in gloss and I will be painting the truck in satin black with Hotrod Flatz. Heres how it sits currently. Every nut and bolt has been replaced with new.
Old 12-20-2012, 10:54 PM   #11
74 stepside
Almost ready to drop in. Saturday Night Special converter in with t400 trans.
Old 01-20-2013, 12:54 AM   #12
74 stepside
Installed the motor/trans. Started on the front suspension. Waiting on new bushings for the rear leafs, then they go on. Cleaning up and painting steering box and linkage too.
Old 01-20-2013, 01:24 AM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
Very NICE!
Keith
Convert to disc brakes.
Old 01-20-2013, 01:31 AM   #14
74 stepside
Very NICE!
Thanks!
Old 01-20-2013, 02:24 AM   #15
moregrip
moregrip's Avatar
Very detailed! Looks awesome!
moregrip is offline   Reply With Quote
Old 01-20-2013, 11:45 PM   #16
luifer76
luifer76's Avatar
nice work man.....looks really good.
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 02-18-2013, 01:53 AM   #17
74 stepside
Havent made alot of progress, but some is better then none. I have the long 8 spring packs. I removed 3 leafs on each side, then removed the rubber/steel bushings. Found out on the HD springs that the front bushing is a bigger size. Then wire wheeled them, painted satin black and installed the new bushings.
Old 02-18-2013, 02:03 AM   #18
74 stepside
Painted the front steering satin black then I cleared the tierods to give them the stock look without rusting. Wire wheeled the rear end and sprayed it the same color as the motor/trans. Driveshaft will get same paint also after I get new u-joints.
Old 02-18-2013, 02:04 AM   #19
74 stepside
Rolled it back into the garage and called it a day.
Old 02-18-2013, 10:25 AM   #20
northeimcustom
northeimcustom's Avatar
Looking good!
*^MY BUILD STORY^*
northeimcustom is offline   Reply With Quote
Old 02-18-2013, 07:37 PM   #21
74 stepside
Old 02-18-2013, 07:38 PM   #22
74 stepside
Thankyou
Old 02-22-2013, 06:38 PM   #23
74 stepside
Well I traded one of my t400s for a built 700r4. It has a shift kit and nice stall with it. So Ill be painting it and swapping out the t400 that currently sits in my frame. While Im at it, Im going to swap out the 3.40 geared 12 bolt to my other 12 bolt with 3.73 gears. Since I have 2 trucks, I have the extra parts. Makes it easier and more cost effective. More pics to come soon.
Old 02-22-2013, 07:40 PM   #24
Telecasterjoey
Awesome build! super clean!
Telecasterjoey is offline   Reply With Quote
Old 02-22-2013, 08:18 PM   #25
panhead671
panhead671's Avatar
Very, very nice!
Fris...Lover of Longbeds
85 C10 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=452581
panhead671 is offline   Reply With Quote
