Old 06-02-2009, 11:29 PM   #1
GMC406
Professional Grade
GMC406's Avatar
Lowering questions
I am looking for a cheap and easy way to lower my truck a little bit. I know this question has to come up alot, but just needing to know the details. The truck is a LWB 71 GMC with rear leaf springs. If I chopped 2 inches off my coils in front and made a longer shackle in back (about4"). What are all the small details I would encounter. Like will my camber be way outta wack up front? Will I need to cut off my axel mounts and rotate the rear axel to get the pinion angle back in line? Other than drop shocks I think I can get by for free that way. Any input is greatly apriciated!
61 GMC 9' Step
Someday it will be a build http://67-72chevytrucks.com/vboard/s...=1#post3356828
67 C-30 Red Dale motorhome http://67-72chevytrucks.com/vboard/s...31#post3845531
71 GMC Street performer in the works
Waiting for warm weather
http://67-72chevytrucks.com/vboard/s...d.php?t=341946
1990 GMC Sierra GT-sold
1983 chevy 4x4-project on hold maybe sell
1969 Triuph GT 6- sold
1996 Ford I-6 5 Speed 4x4
2004 Dodge Intrepid- milage maker
1959 Ford Fairlaine, factory a/c 292Yblock- sold
1982 Honda XL500R
Always lookin for other old trucks!
GMC406 is offline   Reply With Quote
Old 06-02-2009, 11:38 PM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: Lowering questions
whoa, easy there! usually a taking a coil off the front springs will net about a 2" drop. don't use a cutting torch to do this (I'm sure you probably already know this) - cut off wheel, sawzall, etc is the way to go. You will still have to get the truck aligned, regardless of what you do.
As for the 4" rear drop, no need to cut off the axle pads and move them! Just get a 2 or 4 degree pinion shim (wedge) to adjust your pinion angle, but you'll have to measure the pinion angle when you lower the truck to know exactly what shim to get. The shims usually run around $20 bucks. If the pinion angle isn't right, you might get some undue vibrations and possible accelerate wear on your carrier bearing (if you have one).
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 06-02-2009, 11:45 PM   #3
GMC406
Professional Grade
GMC406's Avatar
Thanks for the quick response and no I was not planning on using a torch. My front end already uses 4 or 5 shims already how much more would I be adding to that? And as far as that pinion angle how do you measure that to find out what shim you need?
61 GMC 9' Step
1982 Honda XL500R
