Old 11-29-2014, 09:22 PM   #1
Possmguts
Possmguts's Avatar
Blood Sweat and Tears.. 67 Build Thread
Ok, here we go...
I just started on the tear down today a little bit by going straight to some spots on the body that I knew was already worked over the wrong way. I just didnt know how wrong it was until I broke out the grinder... I have never seen so much bondo in my life... The front roll pan was a home made deal using extremely thin sheet metal and TONS of bondo. The tailgate was smoothed (I use the term loosely) with the same thin sheet metal and bondo, but is going in the book as a lost cause after pulling the sheet off from the inside that was covering some bad cancer. I decided to not even waste my time on the out side knowing it is probably just as bad.
Stay tuned for more of the tear down...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 11-30-2014, 08:02 PM   #2
Possmguts
Possmguts's Avatar
Re: Blood Sweat and Tears.. 67 Build Thread
Pulling the front clip off tonight and hit a brick wall with the wiper arms... of all things lol
I sure would like to have a word with the wiper arm engineer guy from back then right about now.
Any suggestions on how to not mangle them trying to pry them off while dealing with the clip?
Old 11-30-2014, 09:09 PM   #3
Saclandman
Saclandman's Avatar
Good luck with your build. The truck looks good, but I guess looks can be a bit deceiving. Glad you're willing to do it right.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline   Reply With Quote
Old 11-30-2014, 10:48 PM   #4
Possmguts
Possmguts's Avatar
Thanks man. It is incredibly solid. All the bondo Ive removed was only covering dents. I only had one bolt in the front clip that wont come out and its the lower front fender bolt by the rocker panel
Old 11-30-2014, 11:36 PM   #5
dmack91
dmack91's Avatar
The wiper arm should have a small tab on the bottom at the splined shaft. Pull it out lightly with a screwdriver or hook tool and then work the arm off the shaft. Sometimes they can just be gently pried off (most of the tension is from the spring inside the arm holding the arm to the windshield).
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 12-01-2014, 10:20 PM   #6
Possmguts
Possmguts's Avatar
I got em off.. the PO painted the splines so they was really really holding on..
Old 12-03-2014, 06:38 PM   #7
Possmguts
Possmguts's Avatar
Little bummed to find out I dont have a 4 bolt main and its from a 85 to 94 truck... I knew it was newer because of the metric bolts hear and there. Oh well.
Any way, the front clip is off and I see it has been in a bit of a wreck at some point.. the right front fender is from a 68 and the radiator support is bent up a bit on that side.. the deflector is bent up as well. The frame horns look to be straight though so thats some good news...
I should be able to go get the Vette suspension this weekend and maybe order a few other parts. I have a couple friends that collect 67 c10s, blazers, and burbs that I can get some stuff off of. they get all their parts from the Mid-West and anything I get from them should be rot free. I know they have a core support so thats a start.
Ill be selling some stock stuff like the hood and front suspension with cross member as I pull it off and also have a sweet like new bench seat thats comfy as hell Ill sell too.
More updates coming soon.
Old 12-05-2014, 06:11 PM   #8
Possmguts
Possmguts's Avatar
Whats a short bed weigh? Just the bed... Anyone know?
Old 12-06-2014, 11:40 AM   #9
67c10rustbuket
67c10rustbuket's Avatar
Looked like a real nice truck to start with. Amazing what paint can hide. Still looks like a good start. I'm not sure of the bed weight but I remove and install mine with an engine hoist and two yellow ratchet straps cris crossed.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 12-06-2014, 12:34 PM   #10
Possmguts
Possmguts's Avatar
Thanks. It really only has a few spots that need re-worked on the body. There is no patching of any rust on it it needs. Right front fender and the core support and driver side cab corner and tailgate is all I will have to patch or replace. Left side bed rear corner had a few small dents that need more metal work and less bondo. The wiring needs replaced because of dry rot and crispy wires but Should be a pretty easy build. The suspension is the only Real challenge.
Old 12-06-2014, 12:55 PM   #11
ripper70
ripper70's Avatar
Nice start! Man when my truck started i NEVER expected to find so much rust. But shes rust free now. A TON of rust was cut out. Another 1 of our trucks SAVED and put back on the road! Check out the metal work on my build thread. Post as many pics as you can. Good luck!
1970 K20
1967 Blown Stepside
2016 Chevy 2500 Duramax
1989 Jeep Cherokee
1995 S-10
2014 Infinity Q-50 AWD
1970 Chevy K20 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=634164
1967 stepside rebuild
http://67-72chevytrucks.com/vboard/s...d.php?t=684913
Shop build http://www.garagejournal.com/forum/s...d.php?t=225559
ripper70 is offline   Reply With Quote
Old 12-06-2014, 01:32 PM   #12
Possmguts
Possmguts's Avatar
sweet, glad you was able to save it. Always makes me happy to see a classic resurrected.
Pulling the bed off in a little bit when help gets here and Ill post some more pics of the tear down.
Old 12-06-2014, 03:12 PM   #13
Possmguts
Possmguts's Avatar
More pics of the tear down showing some things that need attention...
Still looking good all in all... I have no idea what that big chunk of the frame was torched out for? You can get a good look at how NOT to lower a truck by the way the coils are collapsed. SMH.... do NOT heat coil springs!
Old 12-06-2014, 03:15 PM   #14
ripper70
ripper70's Avatar
THAT was quick..lol. You defiantly got a nice project.
1970 K20
1967 Blown Stepside
1989 Jeep Cherokee
1995 S-10
Old 12-06-2014, 10:16 PM   #15
Possmguts
Possmguts's Avatar
This is gonna look so nice... and its only gonna cost me a kidney and a testicle...
Old 12-07-2014, 06:57 PM   #16
RRR18
RRR18's Avatar
Subscribed. I'm not far from you. Seems as though we are going to be going through a bit of a resto. You got a little head start. I'm almost afraid to even begin. I'll be watchin ya.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 12-07-2014, 07:11 PM   #17
flashed
Im in for the rest of your build .
flashed is offline   Reply With Quote
Old 12-09-2014, 10:06 PM   #18
Possmguts
Possmguts's Avatar
Just remembered I did this video as my "before" video... Im regretting not doing a massive burnout video now though...
https://www.youtube.com/watch?v=chPpoyFtQuw
Old 12-09-2014, 11:53 PM   #19
JonnyC10
Nice. Wish I had a fleetside sometimes.
JonnyC10 is offline   Reply With Quote
Old 12-10-2014, 06:09 PM   #20
Possmguts
Possmguts's Avatar
I was off today and couldnt just sit around... so i went out and started stripping.. the old fashioned way.
Got a pretty good start. The fender is only held on with 2 bolts as I wanted to see how it matched up to the door with no filler or a gazillion layers of paint... undecided on trying to save the other fender or replace it. Its a 68 fender with a horrible patch job over the side light hole.
Need something smaller to get in the low areas on back of the cab..
With any luck Ill have it down to metal all around the outside next weekend and will only have to blast the inner and under stuff, and door jams and what not and then once I pull all the glass and handles Ill clean those areas up, but for now its a start..
Old 12-10-2014, 06:16 PM   #21
flashed
Considering where you are from your truck is very solid ,I love seeing your progress .
Old 12-10-2014, 06:25 PM   #22
Possmguts
Possmguts's Avatar
I bought it from Auburn Alabama and had it shipped home this past summer.. Its been a southern truck all its life. Seen it on Ebay one night at around 1am right after it was posted while I was on the road and figure since its easier to ask for forgiveness than to ask permission... I hit the buy now button lol
Old 12-10-2014, 06:32 PM   #23
flashed
That explains a lot .
Old 12-10-2014, 08:43 PM   #24
RRR18
RRR18's Avatar
Damn....got quite a bit done.
'67 BAD IDEA
Ryan
Old 12-13-2014, 11:39 AM   #25
Possmguts
Possmguts's Avatar
Well I guess thats what I get for buying stuff when Ive been drinking... I got the gauge carrier this morning and its made from ABS Plastic... not CF at all!
How can someone justify selling a thin plastic part for 140 bucks?? Im not even sure it will hold the weight of the gauges without warping in the heat of summer...
