Old 09-17-2020, 07:57 PM   #1
Reno
Reno's Avatar
Cummins Transmission crossmember
Anyone have pictures of their transmission crossmember?
I’ll soon be fitting mine and looking for ideas...I’ll be running a 47RH transmission
Attached photos of my progress - 1972 suburban 4x4 frame, Cummins 12v with Rob Bonney box kit - I’m not the welder.
Reno is offline   Reply With Quote
Old 09-22-2020, 01:22 AM   #2
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Cummins Transmission crossmember
On my 72 I used 2x4 1/4" wall and made a completely new cross member. Using a stock cross member will be tough because your boxing plates won't allow the stock one to set inside the frame. Unless you plan to bolt it under the frame?
Ryan
1969 Chevy milk truck
Old 09-22-2020, 07:19 AM   #3
Stormin08
Stormin08's Avatar
this is what my 2002 ram 2500 cross member looks like
https://www.ebay.com/i/363081831901?...yABEgLKLfD_BwE
much better options out there or fab one to match your rails
Stormin08 is offline   Reply With Quote
Old 10-29-2020, 07:45 PM   #4
Reno
Reno's Avatar
Dieselwrencher -
What did you use then for transmission mount? I’m referring to the rubber mount that buffers vibrations etc
Old 11-02-2020, 02:16 PM   #5
Dewey72
I used square tubing and the stock mount just made a adapter.
Dewey72 is offline   Reply With Quote
Old 11-20-2020, 01:59 PM   #6
diesel burner
diesel burner's Avatar
I don't like being negative, but i have to ask if you have trial fit the motor in the mounts with the cab and core support in place. I also bought the rob bonney mounts and frame kit and just started assembling it all. If i remember correctly the instructions said to start mount placement 18" ahead of shackle mount. I found that to be about 5" too far forward. Using the 3 holes on top of the frame as reference, the front of the motor mount plates line up with the rear hole. Looking at your pictures, I'm afraid you may be 4-5" too far forward. I hope I'm wrong for your sake, but I had to ask because your pictures don't look like mine.
71 C10 Cheyenne 396, turbo 400
71 C20 Custom Camper 383,tko 600,14 bolt project
71 K20 Custom,Cummins,NV4500,NP205,dana 60F,dana 80R
06 GMC sierra 2500 extended cab duramax,allison
05 Toyota Corolla (commuter)
18 Chevy Tahoe RST (wifes car)
08 HD Roadglide
diesel burner is offline   Reply With Quote
Old 11-20-2020, 10:30 PM   #7
Reno
Reno's Avatar
In the picture my engine crossmember isn’t welded in place - it’s to be determined where it will go based on test fitting the engine & transmission.
Engine & transmission should be back from the shop & will take it and frame with body bolted to the frame back to fab shop for final fitment.
I’ll post results soon
Old 11-21-2020, 10:27 AM   #8
v30crewcab
v30crewcab's Avatar
I used a stock 84 cucv cross member and dodge mount when I had a 47rh. then when I went to a nv4500 I used my stock 88 cross member and mount.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
