Old 03-09-2019, 02:49 AM   #1
Dodge68charger
Shaving Bumper Bolts?
Any tips, Tricks, Or Techniques? Thank You
Dodge68charger is offline   Reply With Quote
Old 03-09-2019, 11:09 AM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Shaving Bumper Bolts?
Clean the bumper really good where you weld it.
I did mine about 30 years ago. Take the bumper and have it installed so you get the right angle on the bolts into the brackets and tac them off then pull it off and weld it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-10-2019, 02:03 PM   #3
Overdriven
I’m a little confused by your last sentence Andy. With bumper installed and lined up, tack weld the bolt heads to the bumper so the bolts will stay aligned. Remove the bumper and weld the bolts to the bumper from the backside. Grind the bolt heads off on the pretty side, weld the gaps shut, grind some more and finish with bodywork.
Overdriven is offline   Reply With Quote
Old 03-11-2019, 07:24 AM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: Shaving Bumper Bolts?
Why I said the same thing you did!
If he is shaving the bolts off I think he knows to do all the rest himself. If not I guess he should hire it out.
Old 03-18-2019, 08:43 PM   #5
brownsville
brownsville's Avatar
after you tack the bolts in place i always like to put a decent size washer on the backside of the bumper around the square end of the carriage bolt. and weld both together then weld the washer to the bumper. It gives a slight reinforcement and more welding surface. then cut the heads off and weld em up. Hope this helps
brownsville is offline   Reply With Quote
Old 03-18-2019, 08:53 PM   #6
jondancer
They sell smoothed bumpers . . .
jondancer is offline   Reply With Quote
Old 03-18-2019, 11:21 PM   #7
YBNORML
YBNORML's Avatar
Exactly what I was gonna say.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 03-19-2019, 06:00 PM   #8
jgr
One more thing; do not over tighten the nut or you WILL dimple the nice side were the weld is.
jgr is offline   Reply With Quote
Old 03-19-2019, 09:22 PM   #9
Andy4639
Old member
Andy4639's Avatar
They do now. They didn't back 28 years ago when I built mine.
