10-18-2021, 03:46 PM | #1 |
When driving, get a squeak as the driveshaft rotates
I have a 1988 700r4 that I bought recently from a salvage yard. I replaced all seals, filter, installed the Transgo SK-700JR kit. Seems to shift and work great but I have this squeak. It's a 2-piece driveshaft (3 u-joints). I replaced the rear u-joint. Still squeaking. So I got the burn on jackstands, got underneath, shifted to N, and rotated the driveshaft by hand. It's definitely coming from the forward area. It could be the front u-joint but it really sounds like it's coming from the transmission tailshaft area. When I was resealing the trans I had the tailshaft housing off because I replaced its seal as well, and inspected the shaft, bushing, and speedo setup.
Still looking for the source of my sqeak.
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24. /Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat / SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed |
10-18-2021, 04:32 PM | #2 |
Re: When driving, get a squeak as the driveshaft rotates
Did you oil the shaft before you slide it in?
Also the center support bushings can squeak. |
10-18-2021, 06:14 PM | #3 |
Moderator
More than likely its a uni joint thats dried out....if they have grease nipples, give each one a shot of grease until it comes out of the ross seals...
There is little chance the issue is inside the trans... I would also make sure the center bearing is not partially seized and noisy.....
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
10-19-2021, 10:29 AM | #4 | |
I did lube the seal and the driveshaft before installing. Hard to type that without laughing. I should have lubed with trans fluid but I actually used petrolium jelly (vasoline)
10-19-2021, 10:35 AM | #5 | |
The center u-joint and front u-joint do not have a grease nipple. I should have replaced them when I had the d.s. out but didn't. Now I'm trying to avoid removal again. Also, when doing all my suspension work I replaced the center support bearing with Inland Empire Driveline high impact polyeurothane unit. https://www.iedls.com/Our_Difference When I unbolt it and lift up the d.S. it spins very freely, without drag, resistance, or noise.
Tags |
driveshaft, squeak, transmission, u-joint |
