05-29-2017, 07:51 AM | #1 |
Active Member
Tight hood hinges
$25 + shipping cost, pp mo
05-30-2017, 08:32 AM | #2 |
Re: Tight hood hinges
I'll take them as long as they are truly tight. Did you happen to check them with the springs off?
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
05-30-2017, 01:03 PM | #3 |
I"ll take them if Glenn passes.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
05-31-2017, 09:37 AM | #4 |
I still want them. Waiting on 6t727t2 to reply.
06-03-2017, 10:10 AM | #5 |
Active Member
Glenn, lowest shipping rate I found for 17 lb from 08008 to 92663 was fedex $37.62
70stovebolt, best shipping 17 lb 08008 to 46590 was fedex 14.97 |
06-03-2017, 10:26 AM | #6 |
Have you checked the hinges with the springs removed? The reason I ask is that I just purchased a set that was tight until I removed the springs and found slop.
06-11-2017, 07:22 AM | #7 |
Active Member
Glen, I haven't removed the hinges, I know that the hood opened and closed fine without any side to side movement.
06-20-2017, 09:07 AM | #8 |
Harry are these still available?, I'm just south of you so I'd assume shipping wouldn't be all too bad.
Thanks, Mike |
09-03-2017, 06:46 PM | #9 |
Active Member
Hinges still available, $25 + shipping cost
09-03-2017, 08:14 PM | #10 |
hi what is shipping to 92648
09-03-2017, 10:17 PM | #11 |
Active Member
Just get a flat rate box from the post office. It will be 18 shipped
09-04-2017, 08:42 AM | #12 |
A pair won't fit. Not sure one would in the current boxes they offer. Why would slop in the hinges matter with the springs off as long as there's none with them on and in use on the truck?
09-05-2017, 06:59 AM | #13 |
in line 14063
