12-27-2015, 10:35 PM | #1 |
New U bolts
front axle u-bolts--anything on the threads? No lock washers so?
1961 chevy K10 my build is------------61K10 build |
12-28-2015, 12:22 AM | #2 |
God is good!
Re: New U bolts
I used flat washers and nylon lock nuts. That was what came with the new set of U-bolts on my lift when I bought it. Originally had flat washers and standard nuts.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
12-28-2015, 12:22 AM | #3 |
Re: New U bolts
Nothing on the threads and they should have the tall ubolts nuts and flat washer or something better. Use appropriate torque and they will stretch and stay tight.
12-28-2015, 01:36 AM | #4 |
Re: New U bolts
Ny-locs not really necessary. If you use a standard u-bolt the threads should be rolled, the hi-nut will be a cut thread, grade 8 flat washer under the nut. Light oil on the threads and torqued properly and re-torqued after some miles.
12-28-2015, 12:05 PM | #5 |
Re: New U bolts
thanks guys--u-bolts have the tall nuts and thick washers. From WFO
