Old 03-19-2016, 05:24 PM   #1
hemi43
hemi43's Avatar
Rear diff chatter
Got most of my truck debugged, but can't seem to be able to get the posi to stop chattering. I had originally put in Amsoil and added 2 of their posi additives but the chatter was still there. Today I dumped that out and replaced it with GL-5 petroleum based 80W-90 and a bottle of GM limited slip additive. Chatter is still there. It's especially noticeable after a long steady drive.
Any secrets to get this thing to quiet down?
hemi43 is offline   Reply With Quote
Old 03-19-2016, 05:45 PM   #2
Mike C
Mike C's Avatar
Re: Rear diff chatter
Have you tried doing tight figure 8's in a parking lot? That will distribute the oil through the plates and hopefully break them loose.
I've never seen one that wouldn't smooth out after doing that and using new fluid. I've got a Moroso Brute Strength in my Camaro with the heavy duty preload springs and it works smooth as glass.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-19-2016, 08:55 PM   #3
hemi43
hemi43's Avatar
I've put almost 100 miles on it this past week, including going around in circles. I decided to throw another bottle of additive in today, but may have to wait a week or so because we got some crap weather coming. Is it possible that the friction material has worn of the clutch plates? This was a low mileage truck, and I didn't even bother to take the posi apart because it was so clean inside.
Old 03-19-2016, 09:20 PM   #4
GMC-YA68
GMC-YA68's Avatar
i've got castrol 80-90 with the limited slip additive in it. No issues and have about 400 miles. What posi do you have?
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 03-19-2016, 09:31 PM   #5
hemi43
hemi43's Avatar
Stock GM clutch type.
Old 03-19-2016, 10:58 PM   #6
warbucket
warbucket's Avatar
I know it's just not right but I use ford friction modifier cm-19546-a1 in my 70 chevelle 12 bolt with factory limited slip. A local speed shop recommended it. It stopped the chattering years ago and I love to launch the car hard.
72 CST 4x4 Blazer, 1 ton
70 SS Chevelle, L78, 396
Everytime someone calls your Blazer a Bronco, God kills a kitten.
warbucket is offline   Reply With Quote
