Old 10-31-2019, 07:36 AM   #1
jeffg1010
jeffg1010's Avatar
Towing with a 2wd Blazer
Who is towing with their 2wd? I was considering getting a small camper to tow to the beach for weekend trips. It is a pretty flat and easy tow. I am thinking something with a dry weight of around 2-3000 lbs w/ weight distribution and sway control. I'll probably add some helper bags and an electric fan. I have disc brakes.
I am selling my squarebody crewcab and my camper so this will be a big change.
Not really looking for criticisms or why I shouldn't do it. I am only looking for feedback from folks who've done it. Possibly to get an idea of what I can get away with.
Jeff
1972 Blazer CST 2wd- My son Sam's Project "S" Project "S"
1970 Suburban - SOLD "One Bad Burb" Photobucket Album
1986 C30 Crewcab - 63K original miles, original paint
Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP...
jeffg1010 is offline   Reply With Quote
Old 10-31-2019, 09:52 AM   #2
truckster
truckster's Avatar
Re: Towing with a 2wd Blazer
I don't have any advice, but that's a nice looking Blazer you've got there.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 10-31-2019, 11:24 AM   #3
Keith Seymore
Keith Seymore's Avatar
My advice is that you should be fine.
A Blazer is basically a short SWB pickup; your weight distributing setup and 3000 lb trailer is probably overkill (although without looking at the trailering guide it may be required according to the factory literature).
Approx 4600 lbs shown (3600 lb car and 1000 lbs trailer); 4 wheel drum surge brakes, no load leveling. I've been all the way to Bakersfield and Phoenix with this setup w no issues.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-31-2019, 07:00 PM   #4
hemi43
hemi43's Avatar
My trailer is 4000lbs dry. It tows OK, but barely. If there's any significant wind, you will have white knuckles.
A Blazer is definitely NOT like a short pickup ! Short pickup has a 115" wheel base, whereas the Blazer is only 104". That is a HUGE difference when it comes to towing.
hemi43 is offline   Reply With Quote
Old 10-31-2019, 08:09 PM   #5
rsavage
rsavage's Avatar
This
Sway control would be important along with tires with stiffer sidewalls. It will tow fine but has very quick unforgiving steering as I am sure you know.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 10-31-2019, 09:38 PM   #6
paul mora
If you were to go to the haul website and go through the site like you wanted to rent a car trailer it would probably not let you tow. I have towed once or twice with my blazer short runs light loads no problem. i tried to flat tow my wives CRV one time and it was mister toads wild ride never tried again. If it were me I wouldn’t use the blazer
Pulatoy
paul mora is offline   Reply With Quote
Old 11-01-2019, 06:56 AM   #7
Keith Seymore
Hmm.
I stand corrected.
Carry on -
K
1979-1986
1986 - 2019
Old 11-01-2019, 07:24 AM   #8
jeffg1010
jeffg1010's Avatar
Thanks to all who actually read my post. Love the pics Keith
As I said in post #1. Not looking for negative opinions from naysayers. This is happening.
Jeff
Old 11-01-2019, 09:59 AM   #9
paul mora
There is a fine line between feedback and criticism and only you can filter out what you want to see once you post something online. We can only give you our experience on a issue and you take it and run. You could have take my post as a negative comment. It was just my feedback for you based on my experience and the possible SAFETY problems when towing. Remember when you diving down minding your own business it is usually someone else that causes the accident and don’t let it be you towing a trailer. Go out and borrow a trailer and tow it down the highway with a wind and pass a couple of large trucks. If you feel comfortable then you go for it!
Pulatoy
Old 11-01-2019, 10:18 AM   #10
Ziegelsteinfaust
I have done it with a 4x4 73+, and it was stock height with E-rated tires. It was my friends, and I drove it from LA to pretty much Havasu city for him. We had a box trailer about 10 foot long 7 foot high on the back.
They have a tendency to wander like a 3 year old at the mall, and winds are a white knuckle affair. When I did it. It was a one way trip of about 250 miles.
So if anything happens wind wise. Take it slow.
Ziegelsteinfaust is offline   Reply With Quote
Old 11-01-2019, 06:02 PM   #11
hemi43
hemi43's Avatar
Hmmm... where are the negative comments?
Old 11-03-2019, 03:26 PM   #12
Blazer690
Blazer690's Avatar
I tow my 1971 21' Hallett,
Blazer690 is offline   Reply With Quote
Old 11-04-2019, 05:54 PM   #13
grillzy
I tow this 21 ft supra ski boat that is a beast. Tows fine but not like a long box pick up not even close.
grillzy is offline   Reply With Quote
Old 11-04-2019, 10:45 PM   #14
YoungPup1977
From Mooresville to the beach is only a couple of hours, drive 55 and you should be good to go....stay behind a 18 wheeler on 74 I believe it is and draft off of it to make sure you don't over work your old vehicle. Good Luck at the beach !!!!!
YoungPup1977 is offline   Reply With Quote
Old 11-05-2019, 07:20 AM   #15
jaros44sr
jaros44sr's Avatar
jeff, do you have a temp. gauge for your trans.?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-05-2019, 08:56 AM   #16
YoungPup1977
Which coil springs do you have in the rear of the blazer ?
Old 11-05-2019, 09:15 AM   #17
Blazer690
Blazer690's Avatar
I think the're 2 or 3 in. drop springs with a added pair of air shocks off the end of the trailing arms. In jr. collage my buddy towed a 18' behined his '67 camaro convertible.
Old 11-05-2019, 09:36 AM   #18
jeffg1010
jeffg1010's Avatar
I am loving these pics. Makes me want another boat!
I was thinking the same thing.
No, but I plan on adding a cooler and gauge before taking the plunge
Jeff
Old 11-05-2019, 01:27 PM   #19
Keith Seymore
What do the boat/trailer combinations weigh?
I'm not super familiar with boats.
K
1979-1986
1986 - 2019
Old 11-05-2019, 09:46 PM   #20
Blazer690
Blazer690's Avatar
When I did the trailer I used 5000 lbs for the tong weight adjustment. The bottom is 1"thick fiberglass, a sub floor, big block chevy,2 20 gal gas tanks and 4 full length stringers ect.
Old 11-06-2019, 09:25 AM   #21
YoungPup1977
On some of the lakes here in North Carolina, with the boat ramp being a bit steep the thought of converting the 2wd to 4x4 would have to be considered...….towing the boat would work but getting the boat out of the water on a wet ramp could be a tire burner and have all your buddies jumping up and down on the back bumper...LOL !!!
Old 11-06-2019, 06:33 PM   #22
raggedjim
raggedjim's Avatar
... converting the 2wd to 4x4 ...
Sacrilege! A C10 maybe, a Blazer Never!
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 11-06-2019, 08:33 PM   #23
YoungPup1977
Good luck, Rg
I understand the conversion should never happen, but would you pull a boat or a camper with your 2wd blazer asking for a friend.
Old 11-06-2019, 10:02 PM   #24
Blazer690
Blazer690's Avatar
Love my posi.
Old 11-07-2019, 09:29 AM   #25
Mike C
Mike C's Avatar
My Jimmy was the only truck I had for a long time and I towed whatever I needed to tow. I regularly towed my 20’ Malibu ski boat 100+ miles each way with it. The boat/trailer combo probably 4000# give or take. That was with 35” tires. I would think the 2x4 setup would tow your camper setup quite well.
As others mentioned, the boat ramp could be a challenge. The 4 speed makes all the difference in the world IME though. Much less likely to spin the tires with the better control of the manual trans, the torque converter doesn’t allow for that same fine throttle finesse and tires bust loose in spite of best efforts. Which is why I continued towing the boat with the Jimmy and not the C2500 ‘70 GMC that I towed everything else with.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
