03-25-2023, 07:40 PM | #1 |
Transmission Hump Height
Is the trans hump pictured low or high? I have a base '60 Apache with a three speed manual. I thought they came with the low hump but the rubber mat I just bought is too small so it has me thinking....
03-25-2023, 08:39 PM | #2 |
Re: Transmission Hump Height
That looks considerably taller than mine, which I believe is a low hump.
03-25-2023, 09:15 PM | #3 |
You are both showing pictures of a high hump. Normally the high hump is bolted in and a low hump generally is welded in.
03-25-2023, 09:18 PM | #4 |
Both of y'all have a high hump. The low hump has a step up at the rear.
The low hump was bolted in on 60-63 floors.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-26-2023, 06:44 AM | #5 |
Thanks to all who responded. So is it normal to have a 3 speed manual and a high hump on a '60? From what I read it should be a low hump from the factory. This is a one owner (family) vehicle that I don't believe has ever been modified before it came to me.
03-26-2023, 09:40 AM | #6 |
I'm not sure on that, but it's definitely plausible. The front section of the tunnel different between high and low, so if it's been changed in the past, you probably would be able to tell
03-26-2023, 08:10 PM | #7 |
I have a 61 half ton with a 3 on the tree and a 62 one ton with the factory four speed. Other than the hole for the shifter on the one ton they are the same and both bolt in.
