12-06-2008, 07:52 PM | #1 |
dazed and confused
stepped lower control arms
i am still kind of a newbie here. i have seen factory control arms that have a raised ball joint. does somebody make these or does somebody have a link where it shows you how to do this. thanks for any help!
12-06-2008, 07:54 PM | #2 |
PROJECT 7DEUCE
Re: stepped lower control arms
Thats pretty old school what excatly is the look your going for?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-06-2008, 08:05 PM | #3 |
dazed and confused
a cheap way of lowering as i have a welder and a way to get some steel.
12-06-2008, 08:08 PM | #4 |
dazed and confused
or is it better to go with dropped spindles ahd springs. iam wanting about 4/6 drop
12-06-2008, 08:11 PM | #5 |
PROJECT 7DEUCE
Are you leaf or coil in the back. You can cut one loop off the front springs to get alittle lower..
12-06-2008, 08:16 PM | #6 |
dazed and confused
coil in the back. it looks like the PO cut the bottom part of the sping off and welded flat bar to it then bolted that to the trailing arm
12-06-2008, 08:30 PM | #7 |
PROJECT 7DEUCE
For a mild drop like that I think I would just get some springs.
12-06-2008, 08:40 PM | #8 |
dazed and confused
who would you recomened?
12-06-2008, 09:17 PM | #9 |
PROJECT 7DEUCE
You could search e bay or pay 25 bucks to be a supportin memeber her and posta want to buy thread and I am sure there are some boarmembers here who would sell you a set for a reasonable price. Or summit raceing also has the springs.
12-06-2008, 10:01 PM | #10 |
dazed and confused
sounds good thank you
12-17-2008, 10:37 PM | #11 |
Here's how to step the LCAs if you want to go that route. I'm planning on stepping them 2" on my '64, with 3" drop springs. It looks really straightforward if you trust your welding skills, or you can fab it up and tack it together, then take it to a professional to weld it up.
http://www.jalopyjournal.com/forum/s...highlight=tech
Andrew '69 C-20(292, 4-speed) Retired Daily Driver '64 C-10(250, 3-speed) Fixerupper '97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver If I only wanted two pedals I'd have bought a bicycle.
12-18-2008, 01:07 AM | #12 |
A lot of trouble for no more drop than it gives. Take out the coil spring and cut one round off ... cheaper ... faster ... and not near the "ruh roh" factor in case you weld something up a little crooked.
12-18-2008, 01:29 AM | #13 | |
Junior Member
That is if you have the skills to do it your self. I am going to do a set very soon...
frontstreetcycle on Instagram |
