Old 05-07-2009, 08:10 PM   #1
chipflyer
chipflyer's Avatar
Is a 2003 Yukon XL a good rig?
Looked a a 2003 Yukon xl today and was wondering if anyone has or had one and if the model had any type of common issues/problems? Any info would be appreciated.
Thanks,
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 05-07-2009, 08:42 PM   #2
Liz
Catchy title goes here..
Liz's Avatar
Re: Is a 2003 Yukon XL a good rig?
redneck girl n i both do. imho they are damn good vehicles. Josh could fill you in on the normal issues.
Liz is offline   Reply With Quote
Old 05-07-2009, 09:10 PM   #3
Josh
He's got mean nasty FANGS!
Josh's Avatar
I love ours, They have a few issues but mostly were worked out under warranty. The factory equipped a/c compressors tended to grenade internally but usually under 30k miles on them. Ours has 82k on it, we bought it at 58k and have done nothing but oil changes and a rear window motor that were out of pocket expenses. I replaced the cluster under GM special policy warranty when the speedometer stopped working. It needs an intermediate steering shaft but I just lube it every other oil change. Overall they're good trucks with very little to worry about and are a real bargain as cheap as they have become in the past year.
Josh
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
Old 05-07-2009, 09:34 PM   #4
chipflyer
chipflyer's Avatar
Thanks for the good info. I have found a very, very clean, loaded 2003 with 110K miles and its a 4x4 to boot. It doesn't look much bigger than my grand Cherokee when you are looking out the front windshield but when you look back, its a long way to the back of the vehicle.
I need to get a carfax on it, not sure its the "one" yet but for what they are asking and its condition has me thinking pretty hard.
Thanks again!
Old 05-10-2009, 12:51 PM   #5
tvblazer78
Low & Fast!
tvblazer78's Avatar
I have just a Yukon, but I tow with it all the time, we love it!
tvblazer78 is offline   Reply With Quote
Old 05-15-2009, 04:25 PM   #6
Houston54
Good rig but the 2003 is a one off electrical system. The wiring for a brake controller requires a new pig tail available from the dealer to solve a trailer brake activation problem. 2004 fixed that problem. The gauge cluster issue is common, as is the 4whl drive switch going out and the fuel pump.
I have an 03 Z71 Suburban and like it but I wish I had waited for an 05. 110,000 miles is alot for one of these rigs. Things will go wrong on it. I would buy a new one with lower miles.
Houston54 is offline   Reply With Quote
Old 05-18-2009, 08:59 PM   #7
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
My wife has a 02 with 109,000 on it now, The only thing I have had to do to it is replace the rear e-brake shoes. Other than that, just normal maint. When I was at the dealer i saw them regularly with 200k plus and still running great.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
