Old 05-23-2020, 07:46 PM   #1
LuckyRabbit4
Question Small Block 400 (511)
I'm suppose to go pick up a 511 400 Chevy small block in the morning and I need some answers before I spend my money.
I have a 66 c10 3speed column shift. I'm not very sure on the transmission but I've found most have a Muncie M62/M64? As far as I know it's the basic transmission it came with. It's got a 250 straight 6 from a mid 70s Nova.
Will this 400 sbc fit my current transmission? Will I need to convert a lot of parts to fit the new 400 V8 from the 250 straight 6? Any info would be great. Never done an engine swap so help would be amazing.
Thanks!!
LuckyRabbit4 is offline   Reply With Quote
Old 05-23-2020, 07:57 PM   #2
69 C10 LWB
Re: Small Block 400 (511)
You will need a different flywheel because the 400 is externally balanced but otherwise unbolt the 6 and the 400 will bolt in place.
69 C10 LWB is offline   Reply With Quote
Old 05-23-2020, 08:08 PM   #3
LuckyRabbit4
That's great news. Any other helpful tips? I heard the 400 had cooling issues or something?
Old 05-23-2020, 08:22 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
You will need a good radiator. Look at what is put in a vehicle of the era that the 400 SBC for the amount of area you need. A '67-72 radiator will give you the idea. Your truck has a down flow radiator, so I'd recommend at least a 3-row if you don't have AC. Chevrolet cheaped out in '71 and put 2-row radiators in big wagons with AC and ate a bunch of engines under warranty from overheating. It wasn't the engine, it was the piddly radiators.
~Steven
Simi Valley, CA
Old 05-23-2020, 08:36 PM   #5
LuckyRabbit4
I just got a nice 3 row when I started working on this truck so I lucked out there. I understand I'll need to do some work to the engine but trying to convert the truck to mount a V8 shouldn't be too hard?
Old 05-23-2020, 09:47 PM   #6
cwcarpenter98
cwcarpenter98's Avatar
Frame stands are the same between the 250s and a sbc. Bell housing is also the same. If you haven't done so already, you will need to run the radiator in the v8/heavy duty cooling location and put a fan shroud on it. Run a short water pump and you can use the factory shroud. Run a long water pump and you will have to either make your own shroud or you could go with an electric fan
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 05-23-2020, 10:08 PM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
Might want to look at this:
http://67-72chevytrucks.com/vboard/s...5&postcount=10
Old 05-23-2020, 10:21 PM   #8
LuckyRabbit4
Originally Posted by The Rocknrod View Post
I know my engine isn't what came with the truck originally but by the picture and info in this past post my truck must of had a V8 to start with. It has all the same look that the post shows.
Old 05-23-2020, 10:35 PM   #9
cwcarpenter98
Man, that makes it even easier to swap. The previous owner of my truck hacked the frame rails to fit the v8 radiator in the inline 6 spot
Christian Carpenter
Old 05-23-2020, 10:43 PM   #10
LuckyRabbit4
This was an old farm truck that was pieced together as things went wrong. It had a geotracker radiator in it (said geo tracker in big sharpie letters) so no telling what I'll run into as this keeps going
engine swap, help me please, sbc 400, small block
