Old 03-25-2009, 06:09 PM   #1
GHBLUEHAZE67
GHBLUEHAZE67's Avatar
BBC oil pan leak
I am replacing the oil pan gasket on my GEN IV 454. It has a 4 piece gasket and I was wondering what is the best parts and method to install.
I am told felpro has a one piece rubber gasket. Has anyone here ever tried one? Are they any good?
GHBLUEHAZE67 is offline   Reply With Quote
Old 03-25-2009, 06:20 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: BBC oil pan leak
Use a one piece gasket, problem solved
Old 03-25-2009, 07:07 PM   #3
GHBLUEHAZE67
Do you recommend any RTV with the one piece?
Old 03-25-2009, 07:49 PM   #4
truckdude239
truckdude239's Avatar
no rtv needed. i've used 4 piece gaskets with no problems jsut put a little rtv when the 4 corners f the gaskets meet
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-25-2009, 08:13 PM   #5
70stroker
70stroker's Avatar
i used a one piece and put a little rtv in the corners no leaks after 30 plus k
70stroker is offline   Reply With Quote
Old 03-25-2009, 08:20 PM   #6
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
I have used the mr gasket and the felpro one pc - no issues with either - I like the light gray color of the mr gasket better - I still use a small amount of RTV on the corners as insurance
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 03-25-2009, 09:02 PM   #7
GHBLUEHAZE67
Thanks guys.
