![]() Join Date: Nov 2004
Tilt Column Bearings
I finally got my tilt column torn down (what a pain in the ass that was!)
Anyway, I've found all of the wear item replacement parts, except for the two bearings inside of the tilt cup "thing" (circled in red). They're actually in great shape... except I accidentally cracked/broke the plastic cage for one of them ![]() Does anyone have a replacement part number for these?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 04-11-2016 at 02:14 PM. |
Re: Tilt Column Bearings
I can't help with the part number, but I'd like to pick your brain on the disassembly. Did you need any special tools? Is there anything you did, unknowingly, that you shouldn't have? (Like something broke) my tilt column has some play in it that I would like to tighten up, but I'm kinda scared of really messing something up. I wish I had a donor piece that I could learn on
It's a pain in the ass. That's what it is. I hope I can get it back together. The side pins are a pain. You need to find a screw the size that fits and slowly work it out, I used a pair of vice grips sideways and slowly inched it out.
Once it's almost gutted, you have to "punch out" the inner tube from the outer. I used a socket on an extension. Tilt it inside the tube and gently tap out. It taps out through the bottom. That will pop the shift collar off. I know I'm going to scratch the piss out of it reassembling it, so I'm going to get it in primer, paint the upper part black where the shift collar will cover, scratch the crap out of it reassembling it, THEN final paint it. I rewired my regular column and that was a pain, but I imagine one of the hardest parts is going to be getting the turn signal switch wires back in and in the correct location. http://67-72chevytrucks.com/vboard/s...d.php?t=329008 Post #5 is extremely helpful: http://67-72chevytrucks.com/vboard/s...d.php?t=447180
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 04-11-2016 at 04:12 PM. |
I also think I found the bearing... expensive booger, but it looks a little different than mine... and I need two of these???
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
That about looks like mine, got mine from wes @ classic, around the same price. Very hard item to find, lmk if that one works, I'll buy two
If you put a nut on the bolts that you used for your side pins, you can thread them out easier
I'm more confused now. I looked at it closer last night, it looks like the two bearings in the cup are actually a different size, and the outermost bearing that's on the piece that screws in at the top right before the steering wheel looks like the non-tilt bearing.
I meant to take pics last night but fell asleep. I know there's guys on here that rebuild these... just can't remember who. And you can buy them supposedly fully rebuilt... so they're out there somewhere??? For what I bought this column for years ago, and the cost of the bearings/parts, I should have bought a rebuilt one. I'm still going to come out ahead in the end, but not by a whole lot.
![]() Join Date: Apr 2010
These are the tools needed to disassemble and reassemble your tilt column
I didn't use any of those
Yeah... I'm not doing this again... I'll pay the $500 for a rebuilt one next time.
bump with pics. The top bearing *looks* just like the non tilt version, but it's listed as different about everywhere I look.
The ones in the cup are different, one is clearly larger than the other... at +/-$25 each, I really don't want to order the wrong stuff...
Old member
KevsClassics
Is the tilt wheel guy. He does great work from what I have herd. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
