Old 06-25-2003, 03:19 PM   #1
Linus0014
Guest
Posts: n/a
Need Pics of Power Booster & non power booster
I cant figure out if I have power brakes or not. Maybe its working on it so much my brain has turned to jello. Anything to help me figure out would be nice, thanks....
Old 06-25-2003, 03:27 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
power booster
If you have a booster it will look something like what is to the right of the engine on the firewall in this pic (Driver side). The brake master cylinder bolts to it. Without a booster the master cylinder is bolted directly to the firewall.
Thanks to Boardrider for his pic.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 06-25-2003, 03:29 PM   #3
bpmcgee
bpmcgee's Avatar
If you have power brakes, you'll have a hose from your brake booster to the back of your carb or intake manifold.
Brian
bpmcgee is offline   Reply With Quote
Old 06-25-2003, 03:30 PM   #4
Linus0014
Guest
Posts: n/a
in reply, I have an edelbrock 1407 so the check valve line that comes out of the booster goes to the back of the carb?
Old 06-25-2003, 03:31 PM   #5
Linus0014
Guest
Posts: n/a
Sorry about the reply, you beat me to it...
Old 06-25-2003, 03:33 PM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
Yes on the 1407, in back at the base. It may have a plug in there now. If so, you'll need a fitting for it and a small piece of 3/8 flared gas line steel tubing to thread into that fitting. The rubber line to check valve then goes over the 3/8 tubing
Old 06-25-2003, 03:33 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You can also run the hose to the intake if you have a fitting there for it.
Old 06-25-2003, 03:39 PM   #8
Linus0014
Guest
Posts: n/a
Damn I love this Message board, where would I spend all my free(no wait) all my time if this board wasn't here??
Old 06-25-2003, 04:03 PM   #9
Linus0014
Guest
Posts: n/a
one other thing, trying to find out why I get brake fluid coming out the top of the mast cylinder, good rubber seal and lid...Ideas?
Old 06-25-2003, 04:07 PM   #10
CPNE
Resident Curmudgeon
CPNE's Avatar
One or two fastening straps? The one in the pic has 2 straps. These are better than the singles. It could be that the cover and cylinder don't sit flush. If it's new, take it back and get it replaced.
Old 06-25-2003, 04:34 PM   #11
Linus0014
Guest
Posts: n/a
It has one strap
Old 06-25-2003, 04:44 PM   #12
Longhorn Man
The only ones I have seen not leak are the ones that are empty.
Try this. Aother member told this to me, I have tried it, but the truck has yet to see the road.
remove most of the brake fluid from the master. Don't spill it, it'll ruin the paint.
Stuff the 2 portions with paper towels. Use a long flat file (the wider the better) and lightly run it across the top perfecly level. (drag it on the lef and right at the same time)
This will help make a flat mating surface for the rubber to seal on.
