Old 07-17-2010, 02:46 PM   #1
BlackTopMotors
Where do the three AC cables go?
I am installing the cables to the stock AC controller on a 71 but I am not sure which one goes where. I have one cable attached outside the firewall to the plenum but not sure where it and the others attach to the controller with three arms...defrost...outside... Any help would be appreciated!
Thanks,
BTM
BlackTopMotors is offline   Reply With Quote
Old 07-17-2010, 08:39 PM   #2
JimKshortstep4x4
Re: Where do the three AC cables go?
Here are some pics.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-17-2010, 08:46 PM   #3
100%Chevy
I'll need that diagram myself here in a couple weeks!
Thanks Jim.
Mike.
100%Chevy is offline   Reply With Quote
Old 07-17-2010, 08:54 PM   #4
smorg007
smorg007's Avatar
The cable outside the firewall to the plenum attaches to the bottom of the control head, The outlet selector cable attaches to the middle control arm and the defroster cable attaches on the top of the control arm. Here is a picture from the service manual. Hope this helps.
smorg007 is offline   Reply With Quote
Old 07-18-2010, 01:15 AM   #5
BlackTopMotors
Thanks!!! I need to get a service manual, I am trying to go by general knowledge...but it's like reinventing the wheel. Thanks all, you guys know your stuff!!!
Roger
Old 07-19-2010, 09:42 PM   #6
BlackTopMotors
Unhappy Re: Where do the three AC cables go?
Well, I got them in/attached but it was a bit more difficult than I expected. I couldn't get the defrost cable to move freely and after working it a bit I ended up breaking the portion where the loop tip attaches. I had a spare controller and redid the whole thing and even used a spare cable but it's still too stiff/ not as smooth as the others. Anyone have ideas? They would be appreciated. I am not happy using the spare controller/it wasn't in as good of shape...I tried to save the best portions...do the best with what I had but man, it was just one of those days where you put in loads of effort and gain little.
Roger
Old 07-19-2010, 11:31 PM   #7
48richard
48richard's Avatar
Are you using the correct cable for the defroster? The longest one, obviously, goes through the firewall to the temperature door, the shortest one goes to the duct selector box, and the middle-length one goes to the heater/defroster selector. From my own experience you can put these last two in the wrong place and they will work, but then the defroster is very stiff.
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 07-19-2010, 11:49 PM   #8
BlackTopMotors
Yeah, thanks. I have a middle sized one on the defrost but it's still a bit stiff. I was thinking of oiling it a bit...I also checked to see if I have it coiled around correctly and it seem fine, a curve up and around... Thanks though! Roger
Old 12-13-2011, 12:03 PM   #9
El Campo
El Campo's Avatar
I need this
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 12-13-2011, 03:06 PM   #10
Dano69c10
Dano69c10's Avatar
Subscribed! (For later reference.)
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 04-07-2019, 03:21 PM   #11
69-72
69-72's Avatar
The longest one doesn’t go through the firewall. You would think it does since it’s the furthest point away but it actually goes to the defrost door that’s right under the controls. The middle length goes through the firewall
Source: comparing the OE cables that came on the truck. The one going through the firewall doesn’t have a fastener clip on the end that connects to the box on the outside firewall
Tip save and transfer over the end clips off of your old cables when using repro cables. As usual with repro stuff the clips that come with them don’t fit properly
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
