02-15-2009, 06:54 PM | #1 |
Project underway - finally.
Everything must go! Bellhousing, transmissions et al
First up is a transmission. It's a three speed with shift rods. I took a picture of the input shaft so all could see. It shifted great before I too kit out. $75
http://i188.photobucket.com/albums/z...e/IMG_2886.jpg Secondly is a bellhousing for that transmission and a small block. I can make a deal if someone wants to buy both. Separate I'll take $25. http://i188.photobucket.com/albums/z...e/IMG_2889.jpg Air cleaner - it was fogged grey on top, but it's in great condition otherwise. I'l even throw in a paper element. $10 http://i188.photobucket.com/albums/z...e/IMG_2891.jpg The sheet metal that goes under the flywheel and behind the bellhousing - painted orange and it good shape. $15 http://i188.photobucket.com/albums/z...e/IMG_2888.jpg Clutch and Flywheel for a small block. $50 http://i188.photobucket.com/albums/z...e/IMG_2890.jpg Everything else misc in the picture $15 http://i188.photobucket.com/albums/z...e/IMG_2887.jpg I will separate, just ask. Shipping is extra. I won't ship the transmission. Just ask - nothing is to absurd. -Brian
1972 GMC Pre-resto... awaiting allocated funding. |
02-15-2009, 07:12 PM | #2 |
Re: Everything must go! Bellhousing, transmissions et al
Will that bell housing work 4 a muncie 4 speed?
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
02-15-2009, 08:00 PM | #3 |
By any chance is the clutch return spring still there? If so I am interested as long as it is the original. LMK thanks Harold
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
02-15-2009, 08:35 PM | #4 |
heavy71chevy - I don't know and can't verify for sure, but I can say that it's the symmetric pattern - both top/bottom and left/right. If you want, I can measure the bolt holes, but there is more to it than that, I think. I am not really an expert. If you're local, come and take a look. If not, I'll refund your money if it's not (minus shipping of course).
71super - I am pretty sure the clutch return spring is still around somewhere. I'll let it go for $20 shipped to your door if your in the lower 48. Give me until tomorrow to confirm and you can paypal me. BKB001 @ gmail.com (remove spaces). -Brian
02-15-2009, 08:51 PM | #5 |
Found the clutch return spring - original as far as I know. Very stiff. I hated it. Let me know
-Brian
02-15-2009, 08:59 PM | #6 |
Have a 67 with bad transmission. 250-6cyl. Will yours work?
02-15-2009, 09:02 PM | #7 |
I would assume so. I can't be sure, but I haven't heard of different transmissions for V8s versus straight 6s.
Check with some places and come over to take a look if you want. Thanks -Brian
02-16-2009, 08:31 PM | #8 |
Active Member
What is the didtance between the top two holes and the distance between the bottom holes? What would the shipping to 55901 be?
Thanks Don Brace
Don Brace 55 Nomad 56 Nomad 58 Impalla Coupe 58 Bel-Aire 4D HT 61 Impala CVRT 409 4 SP 2- 71 Longhorns Always looking for old toy trains, Juke boxes Pin ball and game machines. |
02-16-2009, 08:34 PM | #9 |
Active Member
What is the condition of the flywheel? How are the teeth.
Thanks Don
02-16-2009, 08:40 PM | #10 |
Top: 8 1/4"
Bottom 9 1/8" Approximately. -Brian
02-16-2009, 08:41 PM | #11 |
Flywheel looks great, no tooth issues (it's been to the dentist regularly)
Shipping on the bell would be around $25 - it's big.
02-16-2009, 10:23 PM | #12 |
Ill pass..I found one in a complete setup here local..but thanks anyway
02-16-2009, 10:39 PM | #13 |
Sorry I will pass on spring. Thanks Harold
02-18-2009, 11:48 AM | #14 |
Spring is gone, everything else remains. I am surprised nobody wants that bell - I just saw one sell for $65.
02-18-2009, 11:12 PM | #15 |
Active Member
Do you have the clutch pedal, Z bar and the two rods?
Thanks Don Brace
02-19-2009, 08:08 AM | #16 |
I swapped to another manual transmission, so most of that is reused. I do, however, have the two shift bars for the column shift. Is that what you need?
-Brian
02-23-2009, 09:11 PM | #17 |
Active Member
Does the bell housing take the starter with the horizontal starter mounts or does it not have any mounting holes for the starter?
Thanks Don Brace MN
02-24-2009, 08:30 AM | #18 |
The starter bolts to the bell. I don't have the old starter stuff though. I have the sheet metal that bolts around the bell though.
Thanks -brian
02-24-2009, 09:49 AM | #19 |
Interested in the dust cover that goes around the starter in the last link!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
02-28-2009, 12:01 PM | #20 |
That flat orange piece? How does ten bucks plus shipping sound? I'll bring it to the post office in cardboard and I'll let you know the actual shipping charge then. Is that okay?
Thanks -Brian
