05-14-2020, 04:06 PM | #1 |
Single pre-bent lines vs bending my own?
I tried to remove the drivers side brake line to replace the brake hose going to the wheel, and rust made sure the line twisted right into oblivion.
Is there a place to get a new line, but just the one? or is it cheaper to bend my own? This is the smallest brake line of the sets sold for about $100 shipped, probably worth about $3... This is the line going from the splitter to the wheel, 1969 C20 non-power drums. |
05-14-2020, 04:21 PM | #2 |
Re: Single pre-bent lines vs bending my own?
For the situation you are describing I suggest measuring the bad line to get an overall length. Then going to a quality auto parts store and get the closest premade line they have. It is better to be too long than too short. Make sure that both fittings on the line are the same as the ones you are replacing. By all means take the old line with you if possible. Then you will need a tubing bender to bend the new tube to match the old one. If it is longer you will need to figure out where to allow the extra length to go and still have both ends hook up and nothing rubbing.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-14-2020, 04:33 PM | #3 | |
There isn't much bend to the original tube, so hopefully they have something close enough... Otherwise it looks like the kits are the only way to get this short tube, after a few hours of looking i haven't found any single lines and the 'front only' kits are just about the same price. Thanks! |
05-14-2020, 04:41 PM | #4 |
Flare tool is cheap if u don’t have one.
Get a length of nickel/copper tubing which bends very easily by hand Cut out old line and use as template to get close. Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
05-14-2020, 06:40 PM | #5 |
Individual brake lines of various lengths and diameters are common items found in a well stocked parts store.. Perhaps you are shopping the wrong place, but proper terminology goes a long way when looking for parts.. The proper term for a single brake line is "individual brake line".. Summit, among others, has a large selection of individual brake lines.. Determine the length and diameter you need and give them a call...
05-14-2020, 06:48 PM | #6 |
napa has several lines in different lenghts
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
05-16-2020, 08:51 PM | #7 |
i was only looking online... after going to the store i was able to get an 8 inch piece, which is about twice as long as it should be... bent it creatively and out of the way and back in business. crossing fingers that the passenger side doesn't seize up as well... wont get to that for another few days. i soaked the drivers side for a few days with PB blaster but it didn't help, i will keep soaking the passenger side until i can get to it. cant wait to be done with this drum brake rebuild!
05-16-2020, 09:34 PM | #8 |
Good to hear you succeeded!
05-16-2020, 10:19 PM | #9 |
Amazon sells flexible brake lines super cheap. It comes in bulk but if your upgrading brakes a lot it pays off. Just need a handy flare kit.
Posted via Mobile Device |
05-17-2020, 12:15 AM | #10 |
The nickel copper tubing is the bomb. You can literally bend it by hand without a bender. As a bonus it was designed for boat trailers so it has a higher corrosion resistance. Any parts store that has the metal tubing should also sell the fittings. If you are worried about removing the line you should really replace it. The last thing you want is for a rusty line to brake when you are jumping on the woe pedal. If this ever happens to you it will be the only time.
