Old 03-03-2008, 03:02 AM   #1
Guy58
Smile intergrated
Can anyone tell me what is ment be an Intergrated and a Non-intergrated engine.
Thanks,
Guy
Guy58 is offline   Reply With Quote
Old 03-03-2008, 06:58 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: intergrated
The only time I've heard a term similar to that used in regards to our trucks is the "integral" or "integrated" intake manifold used on some 6 cylinder engines. All it means is that General Motors in a moment of "dumbness" decided to cast the head and intake manifold into one piece...
Nobody that I know wants an integrated head. I've heard from mechanics, machinists and regular folks like ourselves to stay away from them. Personally, I've never messed with them so I don't know anymore...
Someone else may know more than what I've mentioned..
Here's a bump for you...
68gmsee is offline   Reply With Quote
Old 03-03-2008, 07:44 AM   #3
wibilly
wibilly's Avatar
Re: intergrated
but the rotating assemblys are several pounds lighter if you wanna build one to wind up
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-03-2008, 09:27 AM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: intergrated
The basic engine is the same, just the head is crap
They are ok with the integrated head till they get hot & then the head will prolly crack
You can put the old 250 head, intake & exhaust manifolds on the block & basically have the non integrated version
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
